September 08, 2026, 04:41:11 pm
Hoffman Amps Forum image Author Topic: diode cathode  (Read 4461 times)
Offline joesatch
  • save me from myself.
diode cathode
« on: September 25, 2024, 11:56:24 am »
pot into diode added to cold clipper. What's this do?  I tested it and it gives interesting gain characteristics not simply like a parallel resistor
Re: diode cathode
« Reply #1 on: September 25, 2024, 07:02:15 pm »
The normal cathode V DC there is typically 2 to 3V, so the diode should be forward biased, conducting.
From a DC perspective, the cathode voltage will drop slightly.
From an AC perspective, the impedance at the cathode will pretty much halve, so stage gain will increase, probably nearly double, so maybe 5 to 6dB.
