September 08, 2026, 04:41:44 pm
Hoffman Amps Forum image Author Topic: What is this?  (Read 5332 times)
Offline G._Hoffman
What is this?
« on: October 06, 2024, 09:10:37 pm »
This is the reverb send node (the grid on the Reverb driver stage) on a AB763 kit I built.  1K sine wave.  The clean sine wave is directly out of the function generator.  I'm using a differential probe set to x200 for the signal, but the distortion happens right where I get a howl from the channel.  I assume this kind of distortion isn't normal here?  Everywhere before this, it is dead clean.
https://www.instagram.com/p/DAzioqHNUwK/?utm_source=ig_web_copy_link&igsh=MzRlODBiNWFlZA==
« Last Edit: October 06, 2024, 09:14:21 pm by G._Hoffman »
Re: What is this?
« Reply #1 on: October 07, 2024, 02:32:34 am »
probing directly to the grid can cause unexpected results
do the same test at the plate
does it "howl" with reverb off?
