September 08, 2026, 04:40:43 pm
Hoffman Amps Forum image Author Topic: How to Label Tubes?  (Read 4337 times)
Offline dankinzelman
How to Label Tubes?
« on: November 30, 2024, 02:55:42 am »
Hi, I want to label a group of (output) tubes for sorting. I've tried masking tape but it singes and the adhesive sticks to the tube when I pull the tape off, then I have to clean it off with WD-40 and I'm afraid of damaging the factory label on the tube. Any suggestions for labels or tapes that can handle the heat and are easy to apply/remove?
Re: How to Label Tubes?
« Reply #1 on: November 30, 2024, 06:01:34 am »
I used an empty egg crate and a black sharpie, while "under test".  then transferred them with data collected to tube boxes I had/bought, walla...Dave's tube's with datasheets  :icon_biggrin:
« Reply #2 on: November 30, 2024, 08:25:43 am »
Thanks shooter, so you write directly on the glass with the sharpie? Then how do you remove the writing?
« Reply #3 on: November 30, 2024, 08:35:49 am »
nope, notes on a card
Ik
VP
Vgain
Notes:
wrap the note card around tube, insert into tube box
« Reply #4 on: November 30, 2024, 08:55:12 am »
Black indeleble marker
Offline Merlin
« Reply #5 on: November 30, 2024, 10:56:46 am »
I use a Merisen white marker to write on tubes. I don't actually know how well it holds up to really long term heat, but it works for my needs.
