September 08, 2026, 11:17:14 pm
Hoffman Amps Forum image Author Topic: Fender custom shop 5e3 Rectifier WEIRD problem  (Read 6313 times)
Offline Ariel tube fanatic
« on: January 02, 2025, 10:59:17 am »
Hey All,
After a recent cap change, the rectifier does not light up
Things i've done:
1. verified that the 5y3 is good, tried another, both won't light up
2. high voltage checks out fine, i created a diode bridge and the amp works fine bypassing the rectifier
3. i'm getting 5vAC between the two Yellow wires
4. caps are oriented the right way
5. checked all grounds for continuity, they read fine.
6. fuses check fine
i'm at a loss as to why it won't light up and work, happened after the cap change but i haven't changed any wires or cut anything.
attached is the layout, the layout i have is page 4, schematic is page 1.
Offline Latole
Re: Fender custom shop 5e3 Rectifier WEIRD problem
« Reply #1 on: January 02, 2025, 12:55:55 pm »
The only thing a 5Y3 need to light up is 5 volts on pins 2 and 8 .
Socket pins send no voltage to 5Y3 base or in other words, pins 2 and 8 of the tubes see no voltage.
Or you'll have to tighten the contacts in the socket, which is too loose.
Did you read pins number the right way ?
Before caps change, is the amp was working fine ?
« Last Edit: January 02, 2025, 01:10:14 pm by Latole »
Offline Latole
« Reply #2 on: January 02, 2025, 01:17:53 pm »
Layout page 4 show a one red and one yellow wire on pin 2 and 8 not two yellow
« Last Edit: January 02, 2025, 01:20:11 pm by Latole »
Offline SEL49
« Reply #3 on: January 02, 2025, 01:58:25 pm »
Look at the schematic to understand why.
Offline SEL49
« Reply #4 on: January 02, 2025, 02:02:42 pm »
But are you getting 5VAC between pins 2 and 8 of the rectifier socket? There's a fuse involved.
« Reply #5 on: January 02, 2025, 04:27:52 pm »
Solved, the red wire from recrifier socket to the board filter cap wasnt making good contact, replaced the wire and all is good now
Offline Latole
« Reply #6 on: January 03, 2025, 04:51:22 am »
Great ,
With that bad contact you read 5 VAC on tube socket  before ?
« Reply #7 on: January 03, 2025, 06:36:26 pm »
Yeah i did, the socket was fine, but i wasnt reading 5vac on the board, yet when chexking rhe wire i got continuity, really strange, now that it ia replaced evsrything is fine
« Reply #8 on: January 06, 2025, 04:00:41 pm »
I suspect the OT is bad, voltages are geeat across the board but i'm getting distortion as i turn up the volume and not much happening after 3 oclock
The amp came to me with a burnt screen dropping resistor ( the 5.1k one) a bad capacitor (was probably damaged along with the burnt resistor) could it be that the OT died as well?
