September 08, 2026, 04:41:37 pm
Hoffman Amps Forum image Author Topic: Diagnosing oscillation in Engl Savage 50  (Read 5965 times)
Offline Choan
« on: January 27, 2025, 07:07:55 pm »
Dealing with some brutal parasitic osciallation in this English Savage 50.
It occurs on clean and distorted in high gain, and distorted low gain when everything is cranked. A brutal frequency!
Oscillation seems to be happening on the preamp board. The only thing that makes it go away on the scope is pulling v2. It ceases to exist on all tubes and speaker output. I’ve measured all resistors in v1 and v2, measured electrolytics with ESR meter. Replaced a shorted cap, and there are a few others showing low resistance. Voltages on pre and power tubes seem to be fine, oscillation throws the power tubes into red plating. Hovering my hand  v2 makes it disappear! I made a faraday cage with aluminum tape since the chassis didn’t have any. Installed a 47k grid stopper on v1 for kicks, nothing changed.
Aside from replace the low resistance caps… where should I be looking? The pf value caps? I’m dying on thing thing! Total pain in the arse as there are no markings on pcb for components.
Schematic is here
https://el34world.com/charts/Schematics/files/Engl/Engl_screamer_50_sch.pdf
Offline trobbins
    • Tim's projects and info
Re: Diagnosing oscillation in Engl Savage 50
« Reply #1 on: January 27, 2025, 07:33:32 pm »
How many tubes did you try out in V2 position, given there are 4x 12AX7 in that amp?
Offline Choan
« Reply #2 on: January 27, 2025, 07:51:37 pm »
The client had tried a new pair, my boss tried a new set, and I brought a known good 12ax7 in and tried that too. Chop sticking is revealing nothing physically altering the feedback, no obviously microphonic tubes/caps. We tried new power tubes, as well.
Offline trobbins
« Reply #3 on: January 27, 2025, 08:15:49 pm »
Can you confirm each of the control relay contacts work?
What is the oscillation frequency?  Does it change in frequency/magnitude with tone pot changes, or lead or clean input gain pot levels, or reverb tank disconnected?
Offline Choan
« Reply #4 on: January 27, 2025, 10:09:46 pm »
Control relays haven’t been tested with a meter, but audible clicking and channel/mode switching seems normal. From what I can recall the tone stays the same but volume of osc is effected by the volume and gain. Switching to high gain lead I believe shifts it slight up in pitch but I’d need to confirm. Interestingly the oscillation gets quieter in volume on high gain lead, much louder on clean/lead high gain.
Offline trobbins
« Reply #5 on: January 28, 2025, 05:42:04 am »
Perhaps probe signal on each side of a relay contact being exercised.
Try and identify where the signal originates, or exclude where it doesn't originate.
Offline Latole
« Reply #6 on: January 28, 2025, 06:06:55 am »
I will check for leaking capacitors from the input to V2
I admit it's just a hunch
