September 08, 2026, 04:41:23 pm
Hoffman Amps Forum image Author Topic: Running a 5u4gb in silverface super reverb  (Read 4752 times)
Offline Choan
« on: February 01, 2025, 06:16:44 pm »
Hey guys, I have a mid 70s super reverb that has a 4ohm speaker load in the cab. I have another super that I’ve run a 5u4 in for years, no problem. I was wondering if running the higher current 5u4 in the amp with a mismatched load is dangerous for the PT. I put a spare 5u4 in and the plates read 406dcv, so there’s plenty of room to increase the plate voltage and lower the current with a GZ34.
Re: Running a 5u4gb in silverface super reverb
« Reply #1 on: February 01, 2025, 08:14:46 pm »
You could use a 5R4GB or GYB that has only 2A filament current and drops 50V.  Could also pull the first preamp tube (norm channel) to lessen total curren draw on the PT.
Running a 4 ohm load shouldn't be a problem.   I would have to ask why are you running a 4 ohm load? seems that 4 8 ohm speakers in parallel is 2 ohms. Which is stock config in an SR.
As for your particluar question concerning load mismatch and higer filament current draw by the rectifier being harmful to the PT.  I will defer to others..
Offline Choan
« Reply #2 on: February 01, 2025, 10:55:01 pm »
Appreciate the feedback!
It’s a buddy of mines, he’s got a mix of 2 and 4 ohm speakers in there. The way it’s wired up read 4ohms on the meter. I’ll look into the 5r4 as an alternative.
« Reply #3 on: February 01, 2025, 11:43:18 pm »
All good then
« Reply #4 on: February 02, 2025, 08:02:49 am »
2 ohm speakers  ??
Offline dogburn
  • Meddling Kid (but older)
« Reply #5 on: February 02, 2025, 04:02:03 pm »
Is that reading measuring the actual impedance or DC resistance? If the latter, then the impedance is somewhat higher.
