September 08, 2026, 04:42:30 pm
Hoffman Amps Forum image Author Topic: 6av6 plate voltage range?  (Read 4475 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« on: February 04, 2025, 10:16:51 am »
Hey guys !
6av6 tubes
I got this amp where V1 and V2 plates, are running little bellow the data sheet specification, between 80-90v,
it says 100-250v for  for the plate voltage, should these voltages be above 100v ?
If so where in the circuit to change, plate resistors or power supply node?
Original thread: https://el34world.com/Forum/index.php?topic=31488.0
Thanks in advance!
« Last Edit: February 05, 2025, 03:37:34 pm by uki »
https://soundcloud.com/ukiuki
Re: 6av6 plate voltage range?
« Reply #1 on: February 04, 2025, 12:13:48 pm »
A few tens-of-volts difference won’t make much difference. But if you’re really worried about it, look at the power supply rail first. How worn out is the 6X4? Have you got another one you can plug in?
Offline Merlin
« Reply #2 on: February 04, 2025, 12:38:32 pm »
'Datasheet spec' are just test conditions used at the factory, they're not a target for an actual circuit to aim at. Your numbers look spot-on if your B+ at point 'C' is around 200V, which seems plausible. Sounds to me like everything is working fine.
« Last Edit: February 04, 2025, 12:40:46 pm by Merlin »
Offline uki
    • Uki's Guitar Trip
« Reply #3 on: February 05, 2025, 03:35:45 pm »
The parts are really old from an old recorder, so hard to tell how much work it did before.
Yeah node C is around 200V.
The amp is working fine and sounds good, 7w ish, my concern was if it was too low.
and i forgot to mention the original thread so here it is:
Thanks guys !!
« Reply #4 on: February 06, 2025, 03:52:37 am »
... How worn out is the 6X4?
Yeah, it was more of a rhetorical question.
Although having said that, if you had another one to plug in, you might find it delivers higher B+, or not, tubes being ‘suck it and see’ things’n’all.
