September 08, 2026, 04:41:10 pm
Hoffman Amps Forum image Author Topic: Reproduction Fender Footswitch Repair/Upgrade  (Read 4595 times)
Offline stratomaster
  • Don't guess, measure.
« on: February 06, 2025, 07:16:12 am »
I've been coming across the problem quite a bit recently where the insulation on the center connection of the BF/SF repro switches breaks down and causes the reverb or tremolo to go intermittent.  It's easy enough to snip, strip, and reterminate--but that's kicking the can down the road.
I'm tempted to rewire the switch with XLR cable and a Y boot to some nice right angle RCA plugs, but I wanted to ask what others are doing when they encounter this before going down this rather pricey upgrade path.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Re: Reproduction Fender Footswitch Repair/Upgrade
« Reply #1 on: February 06, 2025, 07:35:29 am »
That plug itself seen to be a problem, it looks like to have a sharp edge in the inside where the cable is, what if open that end a little bit so the cable dont get cut? I mean the end of the plug is bent inwards, bent it outwards, make it straight.
here some interesting plug https://smitherstransformadores.lojaintegrada.com.br/conector-rca-plug-90-graus
« Last Edit: February 06, 2025, 07:39:21 am by uki »
https://soundcloud.com/ukiuki
« Reply #2 on: February 06, 2025, 08:37:19 am »
Most replacement Male RCA connectors don't have the sleeve extension on them.  https://www.tubesandmore.com/products/rca-plug-switchcraft-straight-2-conductor-type-3501mx
thus eliminating cutting into the cable. Solder to the shell externally. These are like the vintage Fender plugs.
Offline Latole
« Reply #3 on: February 06, 2025, 01:47:31 pm »
Offline Deric
« Reply #4 on: February 06, 2025, 08:20:03 pm »
You don't want to use standard XLR/mic cable.  The fender cable has one shielded conductor and one un-shielded conductor.  The shield on the reverb wire keeps noise from the tremolo from bleeding into the grid of the reverb recovery.  Standard mic/xlr type cable is 2 conductors in one shield.
