September 08, 2026, 04:43:21 pm
Hoffman Amps Forum image Author Topic: First time build with AB763 1 Chnl.  (Read 43923 times)
Offline Richs1979
Re: First time build with AB763 1 Chnl.
« Reply #100 on: February 15, 2025, 10:41:58 pm »
Here are the numbers
Rectifier pins 8 and 2 = 5.4 vac
Rectifier pins 4 and 6 both @164.5vdc
Nodes.....
A = 439 vdc
B = 433 vdc
C = 425 vdc
D = 409 vdc
I'm going to have to quit for now. But I'll be at it in the morning. Appreciate all the time you spent on this with me.
« Last Edit: February 15, 2025, 10:52:53 pm by Richs1979 »
« Reply #101 on: February 16, 2025, 06:28:48 am »
You don't have the amp still plugged into the LBL do you? You don't need that any more. It will throw off ALL your measurements.
You sure you have a GZ34/5AR4?
We need the acv on pins 4 and 6 of the rectifier tube and the dcv on pin 8 and pin 2.
Measure each of those 1 at a time, red probe to the pin, black probe to ground.
You did them backwards.
Need ACV on pin 4, ACV pin 6. (See below.)
I forgot; You have protection diodes on the rectifier tube socket. So What I'd like to see is the ACV from the PT's red wires.
DCV on pin 2, DCV pin 8.
« Last Edit: February 16, 2025, 06:49:40 am by Willabe »
« Reply #102 on: February 16, 2025, 07:25:12 am »
Measured pin 3 on both V6 and V7
V6 = 418v
V7 = 417v
At 1 ohm resistor
V6 = 31.0mv
V7 = 31.0mv
Pin 5
V6 = -49
67 = -49
Nodes.....
A = 439 vdc
B = 433 vdc
C = 425 vdc
D = 409 vdc
Somethings wrong here, 20+ dcv difference between Node A and pins 3 on V6/V7.
It should be the higher dcv, that would seem correct for that PT.
You have to get these measurements right, so you can bias the amp correctly.
Offline Richs1979
« Reply #103 on: February 16, 2025, 09:44:42 am »
Will take those measurements again later today. In the midst of cleaning up around here with the ice storm we got hit with. What should the voltage be for that PT.? It says 355 vdc on the sheet.
« Reply #104 on: February 16, 2025, 09:54:03 am »
Don't know. Spec sheet number is unloaded, it will be less fully loaded, with all the tubes in.
Offline Latole
« Reply #105 on: February 16, 2025, 10:05:24 am »
Answer #1
Offline Richs1979
« Reply #106 on: February 16, 2025, 11:34:41 am »
I had to stop the cleanup, now it's pouring rain.  Anyway I checked these points again.
Rectifier = both yellow are 5.4 ac
Pin 4 = 160 dcv max
Pin 6 = 160 dcv max
Could those 2 diodes be messing something up. The voltages dropped a few times down to 142 vdc before stabilizing at 160. Stupid question but shouldn't this voltage be around 175 dcv with thos ht secondaries rated for 355 v?
Filter caps nodes
A = 426 (2 in parallel 22uf 500v)
B = 418 22uf 500v
C = 408 22 uf 500v
D = 385 22 uf 500v
These are F&T caps that Mr. Hoffman put in this kit
« Last Edit: February 16, 2025, 11:42:42 am by Richs1979 »
Offline SEL49
« Reply #107 on: February 16, 2025, 11:55:36 am »
Pin 4 = 160 dcv max
Pin 6 = 160 dcv max
Yes they are. The AC voltage Willabe wants you to check is actually on pins 5 and 7 (the pins where the PT red wires are connected).
Offline Richs1979
« Reply #108 on: February 16, 2025, 01:03:41 pm »
Ok will do. Be back in a little while. Trying to clean up here b4 the deep freeze 2night.
Offline Richs1979
« Reply #109 on: February 16, 2025, 01:13:19 pm »
No read on 5 and 7. Meter just jumps around. Should I just pull the diodes out and rewire to pins 4 and 6?
« Reply #110 on: February 16, 2025, 01:30:54 pm »
No, leave the diodes.
Set your meter for AC voltage.
« Reply #111 on: February 16, 2025, 01:33:30 pm »
We need DC voltage on pin 2, DC voltage pin 8.
« Reply #112 on: February 16, 2025, 01:46:33 pm »
A = 439 vdc
B = 433 vdc
C = 425 vdc
D = 409 vdc
B = 418 22uf 500v
C = 408 22 uf 500v
D = 385 22 uf 500v
These reading shouldn't be that different.
from now on, measure your AC voltage at the right wall before you take any more power supply voltage readings and post that 3 too.
Is your meters battery old?
Offline Richs1979
« Reply #113 on: February 16, 2025, 01:59:59 pm »
I was ready to check the wall outlet when I read this post. I did remove the diodes and rewired to pins 4 and 6. I get a  max of -19 on both and then it just jumps around. The dc reading on pin 8 is 428 vdc. I will check my battery and outlets right now. Thank you again.
« Reply #114 on: February 16, 2025, 02:04:48 pm »
Do you know if your wall ac voltage goes up and down a lot?
« Reply #115 on: February 16, 2025, 02:06:09 pm »
Is that   -   as in negative?
19 what?
AC? DC?
Offline Richs1979
« Reply #116 on: February 16, 2025, 02:16:37 pm »
Yes That was -19 on both 4 and 6 after I pulled the diodes out. Battery reads 9.4 volts but wall outlet reads 118
Offline Richs1979
« Reply #117 on: February 16, 2025, 02:21:52 pm »
Just wanted to add that we've had brown outs lately due to icing. And who knows with the new smart reader they put in our bill went thru the roof. Nother subject sorry. Yes it does fluctuate. I had a read last month of 123 volts in one if my basement outlets.
Offline SEL49
« Reply #118 on: February 16, 2025, 02:27:28 pm »
Post a pic of your meter.
Offline Richs1979
« Reply #119 on: February 16, 2025, 02:38:39 pm »
I measured new outlets in basement and they're all 120. Here's my old meter.
« Last Edit: February 16, 2025, 02:42:32 pm by Richs1979 »
Offline SEL49
« Reply #120 on: February 16, 2025, 03:06:02 pm »
You either have a faulty meter or operator error. But really, there's no reason to get hung up on measuring the AC voltage on pins 4 and 6 of the rectifier tube because the rectifier is putting out the correct DC B+ voltage. You're way past all that. Just set the bias and call it done.
« Reply #121 on: February 16, 2025, 03:51:09 pm »
He's given 3 different B+ dcv, 22dcv difference.
With 355-0-355 @ 300mA, with a GZ34, the readings he's giving look a little low.
I was trying to find out what was going on.  :dontknow:
« Last Edit: February 16, 2025, 04:03:32 pm by Willabe »
« Reply #122 on: February 16, 2025, 03:56:06 pm »
Yes That was -19 ...
-19 what?
You need to post AC or DC on any voltages you post. (Not that it matters with that reading it's wrong any way.)
On your meter, looking at the pic you posted, going clock wise from the off setting, 1st is DC voltage, 2nd is AC voltage. DC is the straight line, AC is the wavy line.
« Reply #123 on: February 16, 2025, 04:00:25 pm »
So, measure the plate DCV of the power tubes, pin 3, then put that number into the bias calculator.
Use the 6L6GC 30w tube setting.
Set the bias at the 1 ohm bias R in dcmV, then re-measure the plate dcv, pin 3, then plug that number into the bias calculator and re-calculate the bias. Then re-set the bias, should be good then.
Offline Richs1979
« Reply #124 on: February 16, 2025, 04:25:29 pm »
Doides back in measured 414 dcv at pins 3 on 6l6gc. Set bias to 36.7 mA at 1ohm fed from pin 1and 8 power tube
« Reply #125 on: February 16, 2025, 04:35:42 pm »
So, how does it sound?    :m11
Offline Richs1979
« Reply #126 on: February 16, 2025, 04:41:07 pm »
Sounds strong and clean. But the hum is still there. When you turn up the volume the hum goes away. There's no ground buzz from the guitar and when I let go there's no noise.its the hum when the volume is turned all the way down. Can I post a sound file or video on this forum so you can hear it.
« Reply #127 on: February 16, 2025, 04:45:43 pm »
Yes, if you want.
« Reply #128 on: February 16, 2025, 04:52:09 pm »
So, it humms only when your touching the guitar with the amps volume all the way down/off?
Offline Richs1979
« Reply #129 on: February 16, 2025, 05:07:05 pm »
It hums when the volume is completely off. No guitar hooked up. Just the amp on with volume completely down. When raising the volume even slightly, the hum dissipates. I'll be back in a while. Gotta start dinner.,,, Thanks ...
Offline Richs1979
« Reply #130 on: February 16, 2025, 06:16:25 pm »
I turned on the amplifier again and I noticed that if I put my hand above a certain part of the amp, the hum subsides. You don't have to touch it, just put a part of your anatomy over the top of that section. I'm wondering if it just needs some type of a faraday shield. Most of the Fenders I've seen have some aluminum glued or stapled to the cab where the amp sits. I have a piece of thin stock I'll try placing over the top to see if that works.
Offline Calboy
« Reply #131 on: February 16, 2025, 06:24:30 pm »
Can you take  new pin5 power tube measurements and post them.
Offline Richs1979
« Reply #132 on: February 16, 2025, 06:37:59 pm »
Pin 5 is -41.3 volts
Offline Richs1979
« Reply #133 on: February 16, 2025, 06:52:41 pm »
I was right about the shielding. Put some foil over cardboard and the hum is acceptable now. Sounds like my 69 SF.  :l2: Thank you to everyone especially Willabe who stuck through this newbies 1st build. Thank you again. Time to build a cab.
« Last Edit: February 16, 2025, 08:50:45 pm by Richs1979 »
Offline Richs1979
« Reply #134 on: February 25, 2025, 07:55:54 pm »
The finished AB763 build in it's new cabinet.
