September 08, 2026, 04:40:53 pm
Hoffman Amps Forum image Author Topic: spliting plate load resistors  (Read 3931 times)
Offline Jonas
« on: February 10, 2025, 08:31:57 pm »
Could someone help me understand why the plate load resistors are split as shown in the reverb circuit?
reference SLUCKEYS revide (full PDF attached)
Offline trobbins
    • Tim's projects and info
Re: spliting plate load resistors
« Reply #1 on: February 10, 2025, 08:50:58 pm »
Perhaps to adjust the nominal gain from the stage if a different valve model is used that has higher gain.  Perhaps to bring down the signal gain to better suit following stages.
Offline stratomaster
  • Don't guess, measure.
« Reply #2 on: February 10, 2025, 09:02:26 pm »
B+ = Ground from an AC perspective, so it's just a convenient way to build a resistive voltage divider into the plate resistance.  It allows you to cut the signal level while keeping the gain of the triode intact.
