September 08, 2026, 06:44:14 pm
Hoffman Amps Forum image Author Topic: Peavey 6505+ head, signal bleed in lead channel at 0 master volume  (Read 4358 times)
Offline lunchbox21
Hi all,
I got the peavey 6505+ for 420€ used.. Only issue i am having is the lead channel where i can hear signal even at zero master volume ('Post')
Here is the clip of what i mean (sorry for the bad recording):
I have changed almost all the preamp tubes including the V3.
Any help will be greatly appreciated :)
Cheers!!!
Re: Peavey 6505+ head, signal bleed in lead channel at 0 master volume
« Reply #1 on: February 20, 2025, 08:20:01 am »
here's the schematic, maybe,  I had 30 seconds free time, switching circuit would be my 1st rabbit hole.
https://el34world.com/charts/Schematics/files/Peavey/Peavey_6505-20MHC.pdf
Offline Lauri
« Reply #2 on: February 20, 2025, 08:50:33 am »
I would start with checking if VR10 lead post potentiometer works properly. Measure if there's any resistance to ground from the center lug of the pot when it's fully turned counterclockwise. Next suspects are the filter caps for the preamp stages, C36, C37 and C33.
Here's the schematic
https://el34world.com/charts/Schematics/files/Peavey/5150_2.pdf
« Last Edit: February 20, 2025, 09:06:45 am by Lauri »
