September 08, 2026, 04:42:54 pm
Hoffman Amps Forum image Author Topic: Impedance selector wiring  (Read 3812 times)
Offline Snake5150
« on: February 23, 2025, 03:22:32 pm »
Stupid question.
After trying to not use an impedance switch and having a plethora of problems. I’ve decided to install one , few prolly dumb questions tho.
I have a 3 pole selector and only 2 tap? What safety resistor should I add to the third pole for momentary ot safety.
I’m only using 1 jack. The schematic shows the ot common going to one side of the cliff jack and the other side of that jack being a ground . Is this correct? Assuming the cliff jack doesn’t disconnect it?
Offline SEL49
Re: Impedance selector wiring
« Reply #1 on: February 23, 2025, 04:01:16 pm »
Inspect your switch closely. Some of those three position switches have an adjustable stop that can be set to only allow two selections. Otherwise,
No safety resistor. I would just put a jumper between two of the selector lugs. Like this...
