September 08, 2026, 04:43:18 pm
Hoffman Amps Forum image Author Topic: 1969 Super Reverb tremolo tweets like a bird  (Read 5371 times)
Offline fkitch
« on: March 03, 2025, 11:55:57 am »
Hi there
Tried searching online but just found info on the well known ‘tremolo ticking’ issue, nothing on having a little bird in your vintage amp
I did a short video so you can listen to it
Noise was already present before I changed all electrolytics and dog house resistors
Noise starts a couple of minutes after powering up the amp from cold. After that the noise is permanent as long as you use the vibrato channel
Changes in volume control do not affect the tweeting noise volume
Changes in speed control affect the noise cadence (similar to the ticking noise behaviour)
Changes in intensity control do not affect volume of the noise
Any wire dressing attempts made no effect in the noise
V4 and V5 swap had no effect
Reflowed the roach eyelets solder with no effect either
All resistors within spec
I use the correct Fender footswitch
Other than some resistor hiss the amp works and sounds great
Please any ideas as next troubleshooting steps?
I also attach a picture
Offline Rontone
  • Ixnay on the Ampscray
Re: 1969 Super Reverb tremolo tweets like a bird
« Reply #1 on: March 03, 2025, 12:31:57 pm »
I can see a light flash on the video, can you see it on the end of the roach near the edge of the board, that isn't arcing is it?
Looks more like the light inside, is there a little hole on the side?
If you slow the video down the noise seems to happen as the light goes off
« Last Edit: March 03, 2025, 12:44:22 pm by Rontone »
Offline fkitch
« Reply #2 on: March 03, 2025, 01:50:37 pm »
Yes, the noise is in sync with the roach bulb flashing, that’s the light you see in the video and it can easily be seen because the bulb sticks out of the shrink tube a bit (not sure if this is important BTW)
« Reply #3 on: March 03, 2025, 07:48:50 pm »
Maybe time for a new roach and/or LFO cap change (bad ceramic caps maybe introducing unwanted coupling into signal path)?
Not saying it is this. But then again, if you've ruled everything else out...
Offline stratomaster
  • Don't guess, measure.
« Reply #4 on: March 07, 2025, 10:51:50 am »
You can give this a shot before switching out the roach.
« Reply #5 on: March 07, 2025, 06:18:35 pm »
So switching the trem off at the footswitch has no effect, it still carries on tweeting?
Offline fkitch
« Reply #6 on: March 10, 2025, 05:22:55 am »
Thanks for all the suggestions
Looks it is sorted
I realised that changing V4 with V5 was not the smartest option so I used V1 in V4
But what I also did (I broke my rule of doing one thing at a time) was to reflow solder in all the 3 trem oscillator in series caps eyelets
Test… and voilá , tweeting gone, just the good old ticking
Swapped  again V1 and V4 to get original tube back there and tweeting did not come back!
So looks a cold or broke solder joint was the cause… (one of them did look a bit bad)
nope, trem off = no tweeting
did not know about that option!
thanks for the clue!!
