September 08, 2026, 04:42:32 pm
Hoffman Amps Forum image Author Topic: Rectification question  (Read 5183 times)
Offline joesatch
  • save me from myself.
« on: March 13, 2025, 10:20:29 am »
PT repurpose. I want to take the yellow taps from this PT and run them into a rectifier then to filtering and a regulator for 12vdc heaters/relay. The yellows appear to share the CT of the HT reds.  Would i use a 2-phase rectifier on the yellows (since the CT is grounded)? In this diagram they use a bridge rectifier but they are getting +15vdc and -15VDC out of it.
Offline Merlin
Re: Rectification question
« Reply #1 on: March 13, 2025, 10:38:49 am »
It's drawn like a bridge rectifier but really it's a pair of two-phase rectifiers. So yeah, you only need one.
Offline joesatch
« Reply #2 on: March 14, 2025, 01:31:14 pm »
can you estimate what this yellow tap will put out in amps? I need at least 1 amp
« Reply #3 on: March 14, 2025, 02:32:39 pm »
You've not provided any info to base an estimate on.
It's the same as asking how long the piece of string in your pocket is  :icon_biggrin:
Maybe start with where you've got this transformer from?
Offline joesatch
« Reply #4 on: March 14, 2025, 03:37:16 pm »
X60 amp
Offline Merlin
« Reply #5 on: March 15, 2025, 02:59:30 pm »
Hmm, I doubt it. That winding was only designed for a few opamps, probably a few hundred milliamps at most, same as the B+
Offline joesatch
« Reply #6 on: March 16, 2025, 02:20:05 pm »
ya project scrapped. not enough current there.
