September 15, 2026, 12:20:10 am
Hoffman Amps Forum image Author Topic: When your Vintage Fender has seem moisture  (Read 13331 times)
« on: March 17, 2025, 08:35:26 am »
Been going over a my used and abused 1974 Vibro Champ..  it's a great sounding amp but has seen some moisture.
This is what the push-in glides and tolex staples look like on the bottom after years of moisture I guess.
Re: When your Vintage Fender has seem moisture
« Reply #1 on: March 17, 2025, 10:34:35 am »
I sometimes install some small hard rubber feet that have a metal insert and the look great on the Champ/VC and lift it up off the floor, but this time I'm going to install new Fender push-in glides, $12 but oh well..  Now to freshen up the tolex glue and some new staples.
Offline bmccowan
  • Better builder than player
« Reply #2 on: March 20, 2025, 07:19:45 am »
This tip is prevention rather than repair. Know the humidity level in your space and control it. Most basement areas are much higher humidity than people suspect. A simple hygrometer is a $10. drug store or hardware store item. Or a $70 StewMac item if you prefer :laugh:
40-50% is a good level. Good for your guitars, your amps, and even your health. Above 50% and mold, mildew, rust have a life.
If you find your space above 50%, buy a good portable dehumidifier, sized to the space, and set it at 40-45%. If you have a basement drain, its nice to have one with a drain option so you don't need to keep emptying the stupid bucket.
Mac
John Prine
