September 08, 2026, 07:36:01 pm
Hoffman Amps Forum image Author Topic: Check my heater fuse math, please?  (Read 4731 times)
Offline G._Hoffman
« on: March 17, 2025, 09:38:05 pm »
2 6L6GC's (2*.9A), 3 12AX7 (3*.3A), and relay switching stuff (.15A total, though that is on the regulated side of the 7805, but that shouldn't make a huge difference, right?).
So:
(2*.9)+(3*.3)+.15=3.75A
So, do I go with a 4A or 5A fuse on the center tap?  The heater winding on the PT is rated at 5A, and a quarter amp seems a pretty small margin, so I'm leaning towards 5A.
Thanks in advance!
Offline SEL49
Re: Check my heater fuse math, please?
« Reply #1 on: March 17, 2025, 09:46:50 pm »
Putting a fuse on the center tap will do nothing because the tube heater current does not flow through the center tap. The center tap only provides a ground reference to reduce heater hum.
Offline G._Hoffman
« Reply #2 on: March 17, 2025, 09:54:26 pm »
Doh!
I knew that, and just forgot somehow.
So, 2.5A on each line?
« Last Edit: March 17, 2025, 09:59:41 pm by G._Hoffman »
Offline SEL49
« Reply #3 on: March 17, 2025, 10:09:47 pm »
No. the entire 3.75A will be flowing in each line. I would use at least a 6A fuse. But really, why do you even want to fuse the filaments?
« Reply #4 on: March 17, 2025, 10:37:46 pm »
See linked article for suggestion from RG Keen on heater fusing and follow that
https://www.premierguitar.com/the-immortal-amp-mods-pt-2
