September 08, 2026, 03:50:38 pm
Hoffman Amps Forum image Author Topic: Fender Ground Switch Question    (Read 5751 times)
Offline Geezer
« on: June 18, 2005, 06:03:49 am »
        > Fender Ground Switch Question
<< Prev Topic | Next Topic >>
Author  Comment
brookgannon
Junior tube assistant
(3/31/04 1:43 pm)
 What exacltly does the ground switch do for an amplifier? I am planning a scratch build and was wondering if I should include it. It seems that I have heard that with modern grounded outlets thay are not needed why would this be? Thanks Brook
LooseChange
Senior tube assistant
(3/31/04 7:47 pm)
 Re: Fender Ground Switch Question
 If you use a 3 prong (USA) wall plug, you don't need it.
Harry
(4/1/04 12:48 am)
 Back in the day (before I was born mind you) there was no seperate ground on your standard edison wall receptical. The plugs weren't necessarily polarized either. Typically you would want the amps internal "ground" tied to nuetral, but there was no way to know in advance which wire coming in on your two wire cord would be the nuetral and which would be the hot. The ground switch simply applies the amp ground to either wire. If you get a shock from touching the amp then you need to flip the switch the other way.
Now that we have polarized recepticals with ground wires included the ground switch isn't necessary at all. I put one in to fill the old hole, but it won't be attached to anything. Incidently my old 68 twin has a NON ground, 2 wire polarized receptical for the aux AC so I guess they were on there way.
brookgannon
(4/2/04 10:22 am)
 Thanks for the replies. I am a second year electrical engineering student and am currently taking my first circuits class (I have gained some electrical knowledge building amplifieres and in my physics courses). I really apreciate the time spent helping me understand why amplifieres are designed the way they are. Brook
P.S. Can anyone help me with differential equations?
GroundhogKen
Forum Moderator
(4/2/04 11:24 am)
 I actually liked Diff. Eq., but I haven't used the knowledge much since I took the course.
I still remember the buzzwords like Laplace Tranforms and Fourier Transforms, but I'd have to crack open a textbook to remember what to do with the stuff.
Ken
Tiny Daddy
I will work on all amps
(4/2/04 11:36 am)
 I never used that stuff either, in fact did not learn in school what I expected to learn when I applied. But the math helps with understanding things like filter rolloff and phase shift and frequency-domain and hysteresis. School teaches what it is, but not how to use it. The rest you learn from years at the bench and/or computer in an R&D environment, learning from senior people.
zachsdad
(4/2/04 4:24 pm)
 Teach/Learn
 You can be taught how things are supposed to be,
But you must learn how they really are.
LG
 Topic Commands
Powered By ezboard® Ver. 7.32
