September 08, 2026, 04:40:54 pm
Hoffman Amps Forum image Author Topic: 1960s JMI AC10 Twin - I'm stuck...  (Read 7898 times)
Offline Yeatzee
  • I like vintage!
« on: March 23, 2025, 03:05:54 am »
Howdy friends, been a minute! I've got a friend's early 60s Vox AC10 on the bench and I'm a little lost hoping I can get some advice from those much less sleep deprived than myself! (baby #2 born recently)
The ef86 / vibrato channel has a lot more idle noise than I feel like it should, particularly at healthy volumes AND it's not a consistent even noise.
i=pwVq4ruujESyExof
The amp has been recapped and a good number of resistors replaced. I've tried everything to track down the issue but I'm at a brick wall hoping for directions around it!
Things I've tried:
3 different ef86 tubes
2 different Ecf82 tubes
Cleaned all of the tube sockets and pots with deoxit
Replaced every component in yellow (or lifted one lead and temp'd in a replacement for testing)
Nothing has improved the noise in this channel. I tried scoping just the raw idle noise in the preamp to see if I could detect it that way but it's so quiet at that stage that my scope can't really pick it up well enough to conclude anything.
I did also try a trick BGG told me about, which is to use a 0.1uF film cap to ground and touch it to components (discharging between each one) to see where the noise is killed to try and pinpoint it. This pointed me to this section
Touching the cap to any of these components kills it. So I lifted a leg of each cap and resistor one by one and tacked in a replacement and nothing fixed it....
Any ideas? Perhaps the volume pot itself? I did also swap the ef86 cathode resistor and cap to be safe. Maybe it's something really dumb, but I'm stuck and time is not on my side. Thanks for the help!
Bear with me, I'm learning!
www.youtube.com/c/YeatzeeGuitar
Offline Latole
Re: 1960s JMI AC10 Twin - I'm stuck...
« Reply #1 on: March 23, 2025, 03:20:26 am »
Check or replace C4,C5,C6
Or it is a filter caps issue. Are they new ?
« Reply #2 on: March 23, 2025, 06:44:15 am »
did you try this at pin 9 of V1?
Offline Yeatzee
  • I like vintage!
« Reply #3 on: March 23, 2025, 11:31:01 am »
Yeah I tried grounding out the grids, no change.
Offline Yeatzee
  • I like vintage!
« Reply #4 on: March 23, 2025, 12:03:29 pm »
Guess I can lift those and see as well! All electrolytics are new, normal channel has no noise issues.
Offline Yeatzee
  • I like vintage!
« Reply #5 on: March 23, 2025, 01:03:47 pm »
No real discernable improvement. I guess there's a chance it's cumulative, and that any one component isn't making such a big difference that it's super obvious on its own? I'm at a loss, half ready to just shotgun everything temporarily and see what happens.
Offline Latole
« Reply #6 on: March 23, 2025, 01:43:50 pm »
Some wire dress may induce some noise.
Can you move the wires wich are close to the tremolo circuit ?
Offline astronomicum
« Reply #7 on: March 23, 2025, 01:52:32 pm »
I would try lifting R6. That will disconnect the LFO. May help narrow it down. I know you cleaned the pots but there is DC on the Tremolo pot (based on the schematic). I would try putting a jumper across it and see.
Offline Yeatzee
  • I like vintage!
« Reply #8 on: March 23, 2025, 04:30:35 pm »
R6 330k removed, no change so it's not part of that network. Yeah the Trem pot when dimed increases the gain and ends up with about 50vdc there.
Offline Yeatzee
  • I like vintage!
« Reply #9 on: March 23, 2025, 04:31:15 pm »
These are all solid core wire so no real cable management is possible without risking breaking something
« Reply #10 on: March 23, 2025, 05:08:54 pm »
With R6 lifted, you now know it is not coming from the LFO. Jumping out the pot will tell you if the pot is creating the noise.
« Reply #11 on: March 23, 2025, 05:18:55 pm »
But you may already have a finely fractured solid core wire or part which is causing the problem, so...
I think you could (carefully) chopstick the amp (when turned on) to see if any of the connections/wires/parts around the apparent noise-emitting area result in static/hash/popping when tapped/prodded - but only do this if you're confident working on live gear and check you're well-insulated
Another potential issue you could check is whether there's good tension on the V1 tube socket pin clamps - and sub in another tube there
Offline Latole
« Reply #12 on: March 24, 2025, 03:03:10 am »
Can you post some good pictures ?
Offline Yeatzee
  • I like vintage!
« Reply #13 on: March 30, 2025, 02:17:40 pm »
Details in the video (use time stamps it's towards the final quarter).
Long story short I subbed everything out of the amp, swapped tubes disconnected the Trem etc etc. In the end I thought I narrowed it down to the amplitude pot because I had already subbed out the 150k and 0.1uF cap previously but it turned out to be the 150k resistor.... I temp'd in power metal films everywhere when I was testing but I only had two 150k resistors both AB CC's. As fate would have it, one of the two was bad like the original.... What fun!
« Reply #14 on: March 31, 2025, 01:34:59 pm »
Glad you found the issue  :icon_biggrin:
Offline Yeatzee
  • I like vintage!
« Reply #15 on: April 01, 2025, 11:41:07 am »
To close out the series, hopefully this helps settle the discussion re: AC10 input wiring which is pretty odd. I did a comparison of stock AC10 with its 220k's vs 100k parallel resistors on each 220k (roughly 68k final value) vs removing one of the switch tip to ground connections making one input high and one input "low" (more like normal in this amp):
i=ju9DTqigmOxihyMj
I also compared the wattage with and without the 100R plate resistors these had to see if that's really weighing it down or not.
