September 08, 2026, 07:33:13 pm
Hoffman Amps Forum image Author Topic: Troubleshooting Blues Junior Reverb (Update question on Hum, see OP)  (Read 5801 times)
Offline Woodrow F Call
Ok, I got most of this amp sorted out.  New Tank, killed some noise due to cracked solder joints, new input jack, hooked up the speaker wire.
Now the only thing I have left is some hum when I turn up the reverb.  I've looked at the solder joints, reflowed the RCA cable joints on the board.  It sounds like 60 cycle hum.  I move the reverb tank closer to the speaker baffle and get less noise.  I tried vertical, but it gets worse.  I moved closer to the back of the amp and it gets worse.
Anything else I should look at?  The noise isn't terrible until reverb is past 4 (which is just too much reverb anyways), but I'd like to get this dialed in as best as I can.
Original Post Below:
Hey everyone. I got a good deal on a USA made Blues Junior that wasn't working.  Input jack was smashed and a speaker wire was not hooked up.  Easy peasy.  I put in a switchcraft jack and started testing it.  No reverb.
I tap the tank.... I get the springy sound you'd expect. Looking at the schematic (attached), I think this tells me the problem is upstream of the reverb tank.  I check for voltages at the test points TP21 and TP22.  The note says values may vary with the tank. I get 20mV at TP21 and 0.0mV at TP22.
This leads me to think.... solder joint on one of the components or the chip is bad.
Am I missing something?
BTW, I don't have an oscilloscope to check other stuff.  I need to get one just haven't gotten there yet.
I appreciate the help!
EDIT/UPDATE: I get infinite resistance on the input coil of the reverb tank.....  I guess that's probably it?
« Last Edit: March 28, 2025, 05:34:48 pm by Woodrow F Call »
Re: Troubleshooting Blues Junior Reverb
« Reply #1 on: March 25, 2025, 04:40:13 pm »
Try a new reverb pan
Offline SEL49
« Reply #2 on: March 25, 2025, 04:48:00 pm »
Voltages do not vary with the tank. Read note 2 again. You will not be looking for dcv at TP21 and TP22.
Good suspect.
« Reply #3 on: March 25, 2025, 04:58:13 pm »
Well, I just tried the one in my other tank... yup. Bad tank.
« Reply #4 on: March 25, 2025, 05:02:21 pm »
Good suspect.
When I wrote that, I was meaning from tank to tank... is says from pan to pan.  I figured that's why my input was 20mV and not 27mV per the drawing.  I think my meter was set correctly.
Offline SEL49
« Reply #5 on: March 25, 2025, 05:39:02 pm »
Did you have a signal generator set to the proper level/frequency and connected to J1?
« Reply #6 on: March 26, 2025, 10:56:31 am »
I don't have a signal generator or a O-scope (well, one with the leads anyway).
I need to fix that.
Offline SEL49
« Reply #7 on: March 26, 2025, 11:36:43 am »
All those test points with AC voltages (except the 4 test points in the power supply) require you to connect a signal generator set for 10mVAC @ 1KHz to J1. Those test point voltages are meaningless without the sig gen.
« Last Edit: March 28, 2025, 08:03:04 pm by SEL49 »
« Reply #8 on: March 28, 2025, 05:29:00 pm »
Thanks!
Update Question in OP.
« Last Edit: March 28, 2025, 05:39:16 pm by Woodrow F Call »
Offline stratomaster
  • Don't guess, measure.
Re: Troubleshooting Blues Junior Reverb (Update question on Hum, see OP)
« Reply #9 on: March 30, 2025, 01:20:39 am »
Rotate the tank 180 degrees in place.  I often find jacks facing baffle to be quieter.
« Reply #10 on: March 31, 2025, 01:18:45 pm »
Click the link to hear the hum. Can anyone verify if this is 60hz or 120hz?
I have tried a few other things:
Tank is correct.
I've moved the tank around, vertical even. No real change.
Ok, I shorted the RCA cables tip to sleeve. There was no noise.
Checked the power supply voltages on the IC pins (4 and 8 ).... One read 15.01VDC and the other was 15.00VDC.
I did not see any AC using AC or mV settings on my Fluke 117 for the IC chip power supply.
