September 08, 2026, 04:41:22 pm
Hoffman Amps Forum image Author Topic: help with channel debug. massive hiss  (Read 4698 times)
Offline joesatch
  • save me from myself.
« on: April 08, 2025, 11:35:31 am »
i have this channel which I've isolated from the other preamp channel and have it running into the phase inverter directly  (2204 power section). i am getting massive background hiss on this (even with no guitar plugged in). i have tried moving ground locations around and swapped preamp tubes to no avail. Another channel in the amp doesn't have this hiss and if i ground the P.I. input the hiss goes away completely. With the guitar plugged in the channel works fine and tone/volume controls work fine (aside from the massive hiss). I have also tried swapping out the pots. Measured all the resistors and measured for DC coming out of there coupling caps (there is none)
« Last Edit: April 08, 2025, 11:41:00 am by joesatch »
Re: help with channel debug. massive hiss
« Reply #1 on: April 08, 2025, 12:43:05 pm »
how is it "running" to the PI?  guitar cable, wire?
Is the preamp "standalone" or part of an amp?
what happens when you ground the grid of the 2nd stage, WITH the PI connected?
Offline joesatch
« Reply #2 on: April 08, 2025, 12:47:45 pm »
I have disconnected the other channel in the amp (also removed preamp tubes for it)
I have an elevated shielded cable running from the 220k/220k voltage divider to the PI input.  I noticed this channel is very similar to the AB763 normal channel
Offline Merlin
« Reply #3 on: April 08, 2025, 04:01:42 pm »
What happens to the hiss when you turn down the vol pot?
Offline joesatch
« Reply #4 on: April 08, 2025, 04:26:48 pm »
hiss is there with the volume on zero volume adjustment make no difference in the hiss. To me it is a missing ground but i've gone over this a dozen times and there are no missing grounds. could it be a bad coupling cap or cathode cap?
https://youtu.be/FwMx88D4eNI
« Last Edit: April 08, 2025, 04:29:13 pm by joesatch »
« Reply #5 on: April 08, 2025, 05:25:21 pm »
that indicate the "hiss" is in this area.
« Reply #6 on: April 08, 2025, 05:27:07 pm »
did you ever use this channel into the PI??
Offline joesatch
« Reply #7 on: April 08, 2025, 07:47:35 pm »
yes and it has zero hiss. hiss is coming from this channel i posted the schematic of
Offline joesatch
« Reply #8 on: April 08, 2025, 10:25:27 pm »
yup this 220k/220k divider has too much output. that seems to be the issue.  The P.I. needs to have a pot feeding it. I moved some things around in the circuit. this seems to have solved it
« Last Edit: April 08, 2025, 11:56:45 pm by joesatch »
