September 08, 2026, 04:41:35 pm
Hoffman Amps Forum image Author Topic: rectify AC filament for DC on V1  (Read 7733 times)
Offline joesatch
  • save me from myself.
« on: April 11, 2025, 09:17:04 am »
My PT filament supply has a CT. I'd like to rectify this for DC on V1 (rest AC).  If i use an elevated DC for the CT will this diagram work correctly?  the CT will be going to +63vdc but then the rectifier will reference that for ground?  use a FWB rectifier?
Offline joesatch
Re: rectify AC filament for DC on V1
« Reply #1 on: April 11, 2025, 09:27:01 am »
i have seen this as well. what are all those big caps doing?
Offline Merlin
« Reply #2 on: April 11, 2025, 09:29:54 am »
It will work
Offline Merlin
« Reply #3 on: April 11, 2025, 09:32:13 am »
They're trying to have a sort of balanced AC reference to ground after the rectifier. I don't think those caps will do anything very useful but you can try it (but they would need to be rated to withstand your elevation voltage).
Offline joesatch
« Reply #4 on: April 11, 2025, 11:10:49 am »
what about cap rating with your diagram?  do they need to be 100v caps?
Offline Merlin
« Reply #5 on: April 11, 2025, 12:16:10 pm »
C1 needs to be rated for the elevation voltage. The other cap is only across the DC heater (I assume 6.3V).
