September 08, 2026, 04:40:39 pm
Hoffman Amps Forum image Author Topic: Bias circuit assistance.  (Read 4066 times)
Offline joesatch
  • save me from myself.
« on: April 15, 2025, 10:22:52 am »
Using a PT with no CT and i need to power the bias from one leg of the HT secondary. The PT i'm using the same as used in the Marshall Artist.  In this schematic it appears they have set the bias with a fixed resistor which is fine. I am more interested in what they've done before the bias rectifier diode.  HT leg series into a .047u ? cap then a resistor to ground  then into the diode.  What is this doing?  can i series into a resistor instead and not use a cap? Like a standard Marshall that uses a PT with a CT?
Re: Bias circuit assistance.
« Reply #1 on: April 15, 2025, 10:33:47 am »
the un-educated explanation;   :icon_biggrin:
the cap insures only AC gets in, so no "offset DC" between the circuits
the R "fixes" a ground reference for the bias circuit, then it all gets converted to -DC bias, "fixed" to chassis as a reference point.
Offline joesatch
« Reply #2 on: April 15, 2025, 11:29:59 am »
so the resistor to ground is necessary? the PT with a CT doesnt do it
« Reply #3 on: April 15, 2025, 11:56:39 am »
the PT with a CT doesn't do it
apples don't taste like oranges either  :icon_biggrin:
my circuit analysis skills have been traded for farmer stuff so i might be off;
the PS WITH CT is the AC reference to ground
the PS WITHOUT CT uses R1 to reference BIAS supply AC to ground.
« Reply #4 on: April 15, 2025, 12:03:04 pm »
It’s an AC-coupled bias supply. Yes The resistor is necessary- See explanation at bottom of page in link
https://valvewizard.co.uk/bias.html
