October 04, 2026, 11:49:08 pm
Hoffman Amps Forum image Author Topic: Can’t Find the Power Switch option on DIY Layout  (Read 33021 times)
Offline syscokid
« on: April 15, 2025, 12:15:22 pm »
I’ve used DIYLC twice in the past for custom circuit board builds, and used it once for a comprehensive layout simulation. Currently I’m composing another layout and for the last two days I cannot figure out where that darn switch is!
Another bit of info to note: Also a couple of days ago, I installed DIYLC version 5.2.0 to replace version 4.3-something. Couldn’t find the power switch option on either version.
Re: Can’t Find the Power Switch option on DIY Layout
« Reply #1 on: April 15, 2025, 12:41:36 pm »
I don't know what switch you are looking forIf you have one in another .diy file, just copy and paste it to a different .diy file
Save it a building block
Offline acheld
« Reply #2 on: April 16, 2025, 10:28:10 am »
I don't recall a "power switch" in DIYLC.   There are several "micro switches" in the electromechanical section.   I looked at Robrob's site as well -- as he has been using DIYLC for quite some time -- and don't see any there.   He uses the micro switches.
If you need such a switch, you can draw one up, and save it.
Offline syscokid
« Reply #3 on: April 16, 2025, 01:27:10 pm »
Thanks. I did end up drawing one up with a couple connectivity dots. Turned out okay. Hopefully figuring out how to save it to the building blocks will be a lot easier.
« Reply #4 on: April 17, 2025, 05:29:00 am »
Just assemble your component with multiple components and shapes
Select everything
Right Click
Save as Building block
