September 08, 2026, 04:41:12 pm
Hoffman Amps Forum image Author Topic: hot rod deluxe dumble pcb  (Read 5376 times)
Offline Mattjaco1
« on: April 15, 2025, 02:16:36 pm »
Hello i just recently completed a hot rod deluxe to dumble pcb conversion using the luigi retro customs pcb board. The amp sounds great, but i was wondering if anyone could help me get more high end in the clean channel. It sounds very good, just a little dark. Someone on another forum suggested increasing c31 as well as increasing c57. Posting schematic for reference..
« Last Edit: April 15, 2025, 02:19:35 pm by Mattjaco1 »
Offline Latole
Re: hot rod deluxe dumble pcb
« Reply #1 on: April 15, 2025, 02:25:03 pm »
Schematic did not show preamp tubes  :w2:
Preamp tubes cathode bypass cap new value may help
« Last Edit: April 15, 2025, 02:27:44 pm by Latole »
Offline Mattjaco1
« Reply #2 on: April 15, 2025, 02:29:20 pm »
yes it does see v1a and v1b
Offline AlNewman
« Reply #3 on: April 15, 2025, 04:33:36 pm »
So even with all the switching, it's still too dark?
Maybe the best option is to buy an $80 eq pedal and then you can have a switchable option to boost or drop frequencies to get your desired tone, either at the front of the amp, or the effects loop.
The problem with trying to focus on only the clean channel, is it will also affect the drive channel.
Offline stratomaster
  • Don't guess, measure.
« Reply #4 on: April 15, 2025, 07:33:53 pm »
R5 to 82k-120k. 100k is the blackface Fender value.  I've seen Dumble tonestack schematics with values up to 150k here.  I'd start at 82k and play for a bit then adjust further if necessary.
Offline Mattjaco1
« Reply #5 on: April 17, 2025, 11:18:45 am »
100k did the trick. sounds great now! thanks for the help!
