September 08, 2026, 04:41:11 pm
Hoffman Amps Forum image Author Topic: Dual 1MA pot for dwell-volume control?  (Read 3672 times)
Offline ac427v
« on: May 27, 2025, 08:22:17 am »
I sometimes play my newly modified Deluxe Reverb build with the Volume control at maximum and the Master Volume on 3.
Internet lore says that this may result in damage to parts in the reverb driver circuit.
What would be the good/bad effects of reverse wiring the second half of 1 MA dual pot to reduce the dwell at high settings of the preamp volume?
Thanks in advance for your thoughts and experiences.
Offline stratomaster
  • Don't guess, measure.
Re: Dual 1MA pot for dwell-volume control?
« Reply #1 on: May 27, 2025, 09:31:22 am »
There's no damage to be had with that practice.  The biggest concern with master volume controls on AB763 type amps is the minimal headroom in the reverb driver being exposed, but you've already put in countermeasures for that by giving the reverb driver a dedicated HT node at ~350v and reducing the cathode resistor.
You're absolutely fine to make no changes.  But if you want to add a dwell control, I'd be more inclined to replace the reverb control with a dual concentric pot at 250k/500k (500k as dwell, 250k as mix/"reverb") and scale the associated caps accordingly to keep the frequency response unaffected.
« Last Edit: May 27, 2025, 09:35:47 am by stratomaster »
Offline ac427v
« Reply #2 on: June 01, 2025, 06:38:11 am »
Thanks Stratomaster, for taking a deep look at my schematic. Your analysis has me thinking that I have sufficiently reduced the risk of damaging the reverb components when setting the preamp volume at maximum. I will try playing this amp as built before trying to squeeze in a dwell pot. :worthy1:
