September 08, 2026, 04:41:06 pm
Hoffman Amps Forum image Author Topic: 5881 Cold Bias Help  (Read 3080 times)
Offline jjschessmaster
5881 Cold Bias Help
« on: June 02, 2025, 09:59:03 pm »
Hi All!  I built a soldano slo 6l6 nakid following robrobs layout.  I put 6l6s and 5881s in it and currently have 5881.  All works except bias is a little cold I think.
Bias I'm reading 24ma with 453vdc plate voltage with the bias maxed out.  I think thats around 45% dissipation.  Ideally I'd bump that up some.  How would I modify the amp to get a hotter bias?
https://robrobinette.com/images/Guitar/Soldano/SLO-Nakid/SLO-Nakid_6L6_Layout.pdf
Offline Esquirefreak
Re: 5881 Cold Bias Help
« Reply #1 on: June 02, 2025, 11:10:29 pm »
Either increase the 470R or decrease the 7k5R. The former is probably easier. Try a 1k.
/Max
« Reply #2 on: June 03, 2025, 06:54:51 am »
You're the best!  Changed to 1k and I biased up this morning and had enough range.  100% agree not touching that bias pot resistor, I remember more than one frustration wiring that up so the big resistor was easy and accessible
