September 08, 2026, 04:41:30 pm
Hoffman Amps Forum image Author Topic: Line transformers for output.  (Read 4437 times)
Offline silat
« on: June 08, 2025, 11:44:03 am »
Anyone ever use these type of transformer with success?
Re: Line transformers for output.
« Reply #1 on: June 08, 2025, 01:31:03 pm »
Here you can find informations about the use of line transformers as Output Transformers
https://ozvalveamps.org/optrans.html
« Last Edit: June 08, 2025, 01:35:25 pm by kagliostro »
Offline silat
« Reply #2 on: June 08, 2025, 02:06:10 pm »
Thanks Franco! I heard you could use them , but it will take some syphering to figure it out. I have four and they are boat anchor heavy, not the big. Maybe 3 1/2" L X 3" H X 3 1/2" W.
« Reply #3 on: June 09, 2025, 12:56:16 am »
If nobody used one of the transformers you have as OT and report it to you, you must read the explanation on the link and then apply some of the usual math we use to investigate unknown transformers
Do you know how to proceed as to discover turn ratio and reflected impedances ?
p.s.: May be our friends TIMBO and/or Darryl are able to say something about the line transformers use
« Last Edit: June 09, 2025, 01:09:36 am by kagliostro »
Offline silat
« Reply #4 on: June 09, 2025, 06:22:24 am »
transformers
Franco, I have been studying it. Impedance is the turn ratio squared.
« Last Edit: June 09, 2025, 02:23:38 pm by kagliostro »
Offline Williamblake
« Reply #6 on: June 09, 2025, 01:40:13 pm »
I am using one with a Rob Robinette 12AU7 self split output stage as a reverb driver. Works well. Put a speaker on it once just to check and it was really loud. But used a line tansformer that gives me 10k, 20k 30k primary and 4, 8, 16 Ohm secondary, so lots of options to get the load right.
