September 08, 2026, 04:41:10 pm
Hoffman Amps Forum image Author Topic: A humdinger question  (Read 3463 times)
Offline hylaphone
« on: June 11, 2025, 11:41:06 am »
Hi, I'm working on an amp with completely separate filament supplies for preamp and power amp.One will have 100R CT resistors, the other will have a humdinger.Would you use the resistors for the power tubes and the humdinger for preamp? Or vice versa?Thanks --
Offline Merlin
Re: A humdinger question
« Reply #1 on: June 12, 2025, 03:43:01 am »
Humdinger on the preamp makes the sense
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #2 on: June 12, 2025, 02:49:48 pm »
if you are adding humdinger on one, why not do both?
have you considered elevating the filament?
https://www.valvewizard.co.uk/heater.html
Offline hylaphone
« Reply #3 on: June 17, 2025, 04:36:36 am »
Yes, but I was curious if hum from filament imbalance is more of an issue with preamp tubes..I would think it gets cancelled out in a push pull stage..
« Reply #4 on: June 17, 2025, 06:52:16 am »
I suggest to DC elevate both circuits to the output valve cathode voltage.
