September 08, 2026, 03:50:39 pm
Hoffman Amps Forum image Author Topic: NFB Questions    (Read 5633 times)
Offline Geezer
NFB Questions
« on: June 18, 2005, 06:04:41 am »
        > NFB Questions
<< Prev Topic | Next Topic >>
Author  Comment
jbrew73
Junior tube assistant
(4/1/04 9:40 pm)
 NFB Questions
 i understand that the value of the nfb resistor would need to be changed if the output tap used was changed(27k on 2 ohm, 47k on 8 ohm , 100k on 8 ohm etc.) but what happens if you are running a 4 ohm cab on the 8 ohm tap or you pull 2 tubes on a 100watt amp or using a 6.6k transformer where the amp in question came with a 4k. would this change the level of nfb? what i'm after is whether i would need to change the value of the nfb resistor depending on the impedence ratio of the output transformer? don't tell me to try it and see what sounds the best because i'm tone deaf as the rejects on american idol. i want to make sure it sounds good to you guys with  golden ears
Tiny Daddy
I will work on all amps
(4/1/04 10:56 pm)
 Re: NFB Questions
 The NFB should reduce the volume 3 or 4dB, a barely audible change. Or you could measure the gain change with load attached and adjust the resistor.
jbrew73
(4/3/04 12:10 am)
 NFB Questions
 so you are saying to adjust the resistor so the nfb drops the output by 3-4db. and this would compensate for the changes made to the output transformer impedence ratio.
 Topic Commands
Powered By ezboard® Ver. 7.32
