September 08, 2026, 04:40:52 pm
Hoffman Amps Forum image Author Topic: Need Troubleshooting Help  (Read 3451 times)
Offline mar2112
« on: June 12, 2025, 10:40:55 pm »
I rebuilt my Monoprice 15 into a Micro Bassman.
Recently the amp started acting up, cracking and popping as it heated up, and now I have no sound at all.
First thing I did was replace all tubes with no joy.
Then on the bench I injected a 440Hz signal with my phone and traced it, measuring frequency with my DMM (I don't have a o'scope), thru the amp to the output tube. I did find a poorly soldered resistor during this process, but that did not fix the problem.
When connected to a speaker I can hear the OT humming at 440Hz. The humming goes away if I connect the OT to an 8Ω resistor.
I'm leaning towards a failed OT - is there something else I should consider? How can I test the OT with minimal test equipment?
Re: Need Troubleshooting Help
« Reply #1 on: June 12, 2025, 11:57:47 pm »
Use the amp's own PT as a VAC source to measure the Pr:Sec VAC ratio on the OT
With the PT switched off,
Disconnect the OT primary and secondary winding ends from the circuit. Make sure the floating winding ends don't contact anything else (or each other)
Disconnect all the PT secondaries from the circuit. (and do same trick with ensuring no shorts to ground/other circuits etc)
1) connect the OT secondary winding to the PT heater winding. Clip a VMeter cross this connection (to measure VAC - you'll be looking for ~6VAC when you switch everything on)
2) Hook another couple of VMeters to the OT primary  - you want one meter measuring across each half of the OT primary - you'll be looking for 100 VAC or so across each primary winding half.
Switch the PT on (after making sure the mains fuse etc is properly connected and there is no unwanted shorting of leads etc).
Measure the exact VAC across the OT secondary (to confirm the exact voltage (e.g. 6.3VAC etc)
Measure the exact VAC across each half of the OT primary
For a healthy OT, you're looking for the voltages across the OT primary halves to be the same - AND you're looking for the desired Pr:Sec VAC ratio (which will be the square root of the OT's designed Pr:sec impedance ratio)*. Note - for a PP OT, the component you're looking for (to get the Pr:Sec VAC ratio) is the end-to-end VAC across the whole OT primary winding (Edit: also note, this won't be a 1kHz signal, it'll only be 50 or 60Hz depending on the mains in your country - but this is close enough to give you a fairly accurate picture of the OT VAC ratio)
Switch the PT off before touching any leads.
*say you measure 200VAC across the OT primary end-to-end with 6.3VAC measured across the secondary. That's 200:6.3, which is 32:1. 32x 32 =1,024 so impedance ratio would be 1000:1, which is an 8k plate to plate reflected load with a 8R speaker connected to the secondary
« Last Edit: June 13, 2025, 12:37:42 am by tubeswell »
Offline danhei
« Reply #2 on: June 13, 2025, 01:34:37 am »
Did you use the original Monoprice 15 transformers or Rob’s recommended ones for the Bassman Micro?
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #3 on: June 13, 2025, 09:17:38 am »
Measure voltage on the electrolytic caps in power supply before unsoldering the HT wires.
If above one volt (or so) drain them with a test lead connected to chassis and other end to large resistor touch the resistor to the + terminal of cap until voltage is below ~1v
https://el34world.com/Forum/index.php?topic=27668.0
