September 08, 2026, 04:42:29 pm
Hoffman Amps Forum image Author Topic: 1/4w resistors vs 1/2w for preamp plates  (Read 4681 times)
Offline fossilshark
  • No life til' leather
« on: June 17, 2025, 02:40:44 pm »
Accidentally ordered 1/4w 220K resistors instead of 1/2w that the schematic calls for. For plate resistors on 12ax7s will this be a problem? This amp is just being repaired for a friend in a bit of a time crunch.
~SNOWBLIND~
Re: 1/4w resistors vs 1/2w for preamp plates
« Reply #1 on: June 17, 2025, 04:45:42 pm »
(voltage across the plate R ) * ~~~~~ .0015A (about what an AX draws at idle) = power in Watts
Offline stratomaster
  • Don't guess, measure.
« Reply #2 on: June 17, 2025, 04:53:49 pm »
What's the voltage rating of the resistor?  That's the real question.
Offline Merlin
« Reply #3 on: June 17, 2025, 05:40:59 pm »
Most 1/4W resistors are only rated for 200V, which is probably not enough. I suspect you're gonna need 1/2W.
Offline fossilshark
« Reply #4 on: June 17, 2025, 06:50:00 pm »
If Merlin says so then it is. I will order 1/2w replacements. Thanks for the advice!
~SNOWBLIND~
« Reply #5 on: June 18, 2025, 12:04:11 am »
Since I suffer from deforming arthritis in my hands and I am also short-sighted, my preference always goes to nice 2W metal film resistors, which, to be honest, have a look that is more reminiscent of the size of old carbon-bond resistors among other things, even if they were not metal film, 2W resistors are "quieter" than the same type of 1/2W
Offline fossilshark
« Reply #6 on: June 18, 2025, 06:47:26 am »
I will have to see what I can find that will fit in the PCB. Maybe some of vishays ceramic resistors at 1w would be good.
~SNOWBLIND~
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #7 on: June 18, 2025, 08:58:03 am »
Offline AlNewman
« Reply #8 on: June 18, 2025, 06:17:16 pm »
Here's a good quote from PRR from the linked thread.
"You can't burn-up even a 1/4W in grid or cathode service.
If a preamp tube goes dead-short, a 100k plate resistor on 300V supply gets 0.9 Watts.
Toasted carbon-comp is bad mojo, always over-size for reliability."
