September 08, 2026, 04:41:28 pm
Hoffman Amps Forum image Author Topic: Bass PreAmp  (Read 21501 times)
Bass PreAmp
« on: July 19, 2025, 10:49:26 am »
Anyone have any knowledge of building a bass preamp?   I have seen this:
Jule Monique All Tube Bass Preamplifier by Jake Wolf
From what I can gather, it has a tube rectifier, one 6SL7 and one 12AU7  and a Baxandall (maybe James?) tone stack?
I'm wondering if this is somewhat built (loosely) around the idea of a preamp of a Ampeg Heritage B-15 with a built in direct box?
Anyone have any schematics or personal experience building a tube bass preamp?
« Last Edit: July 19, 2025, 02:39:22 pm by kagliostro »
Re: Bass PreAmp
« Reply #2 on: July 19, 2025, 04:02:58 pm »
That Alembic preamp looks good but getting the Toroidal PT to fit in the 1U rack case without creating a short looks like a tight squeeze
Re: Bass PreAmp
« Reply #3 on: July 19, 2025, 04:26:37 pm »
« Last Edit: July 20, 2025, 01:23:44 am by kagliostro »
Re: Bass PreAmp
« Reply #4 on: July 19, 2025, 07:38:02 pm »
This is all very helpful information!  Thank you for taking the time to share this all.
Re: Bass PreAmp
« Reply #5 on: July 20, 2025, 01:27:56 am »
Glad to know you appreciate It
Online glass54
Re: Bass PreAmp
« Reply #6 on: July 20, 2025, 03:04:10 am »
Hi TubeNit;
Built a Bass Preamp for a friend (around 2004, on PCB with chassis mounted Tube Sockets) and it still is going strong  :icon_biggrin:
Two Tx's used for compacted an availability issues in Aussie and used a DC supply for heaters.
I have attached the Sch and have Audio Precision FR responses, etc. You could easily change TCs to other topologies.
If you want, I could do a PM with more info.
Kind regards
Mirek
"To measure is to know"
Offline Lekky
Re: Bass PreAmp
« Reply #7 on: July 20, 2025, 04:21:33 am »
I built a near-clone of Arkham's Oracle preamp a few years ago. There are many gut shots of the Arkham preamps around, so it was easy to figure out the Ampeg-inspired circuit. Schematic is attached.
EDIT: I added an output transformer and XLR output after the schematic was made.
« Last Edit: July 20, 2025, 04:32:00 am by Lekky »
Re: Bass PreAmp
« Reply #8 on: July 20, 2025, 05:38:35 am »
Mirek and Lekky,
This is fantastic information and also very helpful!  Thank you also!
I noticed you both chose to use 12v filaments instead of 6.3v?  Is there any reason that 6.3v filaments wouldn't work? Does it need 12v filaments .......... or is that something you choose because of the power transformers you used?
I'd likely use a Hammond PT with tube rectification and 6.3v winding.
Offline Lekky
Re: Bass PreAmp
« Reply #9 on: July 20, 2025, 06:06:15 am »
I used 12V heater voltage for simplicity, as I use a standard 12V switching wall wart which powers both the heater and the VPump converter. Tube pedal maker Sushi Box uses the same arrangement in his pedals.
I *could* wire the tube socket for 6.3V heater voltage, but that would require wasting power and generating heat through a regulator and/or dropping resistor. It's more practical to use 6.3V if the transformer has a 6.3V heater winding.
Re: Bass PreAmp
« Reply #10 on: July 20, 2025, 06:18:15 am »
Thanks Lekky!  I appreciate the response and it's helpful.
Online glass54
Re: Bass PreAmp
« Reply #11 on: July 20, 2025, 06:23:17 am »
Sorry about the transformer confusion.
I used a (T1)15VA 240:12V Tx for Heaters and powering a (T2) 5VA 12:240V Tx for generating HT due to limitations and cost of suitable 1RU transformers in Aussie.
You can certainly use 6.3V AC for heaters or if you could be bothered use a minimum 2A Bridge rectifier and 4,700u 25V (or up to 10,000uF) electro as DC filter, but you may have to fit a small build-out resistor to bring the heaters back to 6.3V DC (6.3x1.4 minus 2 diode drops gives about 7.6V DC therefore requires approx 1.3V DC drop  :laugh:)
I used a 12V 3 Terminal regulator (LM7812 or similar) offset with a diode (D_P1) on groundpin which gave me +12.55DC (ideal for series heaters)
Taking up Lekky's idea, I have no problems using a DC-DC inverter for PS as long as inverter runs >100kHz and additional RF protection is used. I could demonstrate RF rubbish on PS rails with my APx525 audio analyser  :laugh:
Advantage of such PS topology is reduced size of filter capacitors BUT if you already have a simpler solution, go for it.
Regards
Mirek
Re: Bass PreAmp
« Reply #12 on: July 21, 2025, 07:08:26 am »
OK, here's what I've got so far in the idea. I've built 2 amps that use a H&K Red Box that I'm very pleased with.  So, my thinking is to "keep this simple" and within what I am already familiar with.
My thinking is some of the schematics shared incorporate internal either solid state or tube functions similar to a direct box?  I'd rather just use a direct box mounted on the back of the amp head cab instead IF that is the case?
Anyone see any major flaws in this design?
« Last Edit: July 21, 2025, 07:18:56 am by tubenit »
Re: Bass PreAmp
« Reply #13 on: July 21, 2025, 07:11:19 am »
Here is an example of what I've done in the past that I've found successful and has been used for a zero volume stage. I've had quite a few guitarists play thru this and they've been very favorable to the design.
I'm understanding the bass preamp would NOT need a dummy load resistor. So, the same idea with a direct box without the dummy load.
Amazon.com: Radial Pro DI Passive Direct Box : Musical Instruments
or    Amazon.com: Pyle Premium Direct Injection Audio Box - 2.36" x 4.09" Passive DI Unit Hum Eliminator w/ Input Attenuator to Connect Guitar & Bass, 1/4'' Impedance Transformer Connector to Balanced & Unbalanced XLR : Musical Instruments
The guy I'm thinking about building the bass preamp for ........... owns the one attached.
« Last Edit: July 21, 2025, 07:43:28 am by tubenit »
Re: Bass PreAmp
« Reply #14 on: July 21, 2025, 10:24:28 am »
I'm wondering if a cathode follower would work well with this design?  Perhaps it may add a dab more compression to the tone?
With respect,  Tubenit
Re: Bass PreAmp
« Reply #15 on: July 21, 2025, 11:06:54 am »
not totally sure but I believe the 820 is acting as a CF
Re: Bass PreAmp
« Reply #16 on: July 21, 2025, 11:25:14 am »
Yes the IRF820 is the buffer for the TS load.
But another low impedance buffer just before the preamp output would probably help with pushing the output signal along to the next/main amplifier/whatever.
Re: Bass PreAmp
« Reply #17 on: July 21, 2025, 04:20:58 pm »
agree but the TS will eat up signal, attenuate, so without knowing what's coming out 1st, it'll be hard to guess at just another CF/impedance-match or gain +CF
Re: Bass PreAmp
« Reply #18 on: July 22, 2025, 12:05:56 am »
Also you can consider the use of something like this
https://www.tubetown.net/ttstore/en/audio-transformer-1-1-2-1-for-line-signals-ltr-110.html
It will allow also a Balanced Output (600 ohm with CT secondary)
« Last Edit: July 22, 2025, 09:11:04 am by kagliostro »
Re: Bass PreAmp
« Reply #19 on: July 22, 2025, 10:17:53 am »
There was an italian guy who had a certain celebrity, Gianni Cornara
now if I try to find his web pages the link I find with Google didn't work and if I click on it an error appair
here a pair of his Bass Amp projects
(that were build with satisfaction few years ago but at the moment I didn't find the  soundclips)
For those who can be interested, save the schematics on your computer, this copies comes from my archive because the original web pages of the author don't exist more
300W Tube Bass Amp (note the way he obtain a balanced output from the preamp)
15W Tube Bass Amp
Here you can read a bit about who is the author
He has a degree in physics and is passionate about audio circuits
https://www.audioplay.it/gianni-cornara
https://www.audioplay.it/author/giannicornara
p.s.: Try if this links works, I found it using Google Lens
http://www.giannicornara.net/pages/page_guitaramp-i.htm
http://www.giannicornara.net/pages/page_stbassamp.htm
« Last Edit: July 22, 2025, 10:33:37 am by kagliostro »
Re: Bass PreAmp
« Reply #20 on: July 22, 2025, 11:19:47 am »
THANK you again!  All useful information.
Re: Bass PreAmp
« Reply #21 on: July 23, 2025, 02:41:33 am »
If you build this Preamp
You can omit the Balanced Output and connect a Red Box H & K to the Power amp exit, if you need you can play with the resistors at the exit to achieve the right level to the Red Box
That Preamp is really High Quality
Offline Lekky
Re: Bass PreAmp
« Reply #22 on: July 23, 2025, 08:29:35 am »
Another nice bass preamp design is the Nobelium by C2C Electronics, which is a clone of the coveted Noble preamp. Schematic is in the build document.
Re: Bass PreAmp
« Reply #23 on: July 23, 2025, 10:33:26 am »
All great info!  Thanks!  I'll meet with the guy that's interested in this in a few weeks and then make a decision. I've got a stack of schematics & options to consider at this point.
« Last Edit: July 23, 2025, 01:56:42 pm by kagliostro »
Online Wardy
Re: Bass PreAmp
« Reply #25 on: July 30, 2025, 05:29:48 pm »
Seems I'm on the same quest. Trying to put together a bass preamp with built in compressor and variable HPF.
I built the attached stomp version from Tubetown and I can verify it works well. have gigged with it a couple of times. I'm thinking of using this as base and adding in the other stuff plus a footswitch and let it sit on my stack.
Re: Bass PreAmp
« Reply #26 on: July 31, 2025, 12:31:58 am »
May be you are interestednon this
COMPRESSOR - EXPANDER with ECH84
If diode D is inverted, it functions as an expander. The top potentiometer adjusts the gain.
The bottom potentiometer adjusts the compression.
The 100-500k trimmer adjusts the delay
« Last Edit: July 31, 2025, 12:37:13 am by kagliostro »
Online Wardy
Re: Bass PreAmp
« Reply #27 on: July 31, 2025, 05:09:04 am »
Many Thanks Franco,
I must admit I am struggling to read that schematic. I'll have to print it and enlarge and rewrite so I'm sure what all teh values are. I also found this that you recommended in another thread.https://www.audiovalvole.it/progetto_preamplificatore_compressore_chitarra_basso_elettrico.html
It looks like it could be what I'm looking for but its still confusing. It discusses using a ECC91 and then goes on to specify a 12au7 in the BOM.
I defo don't want to use the ECC91 as I want to use 12vdc for the heater.
Also there is a level control but no ratio.
best
Steve
Re: Bass PreAmp
« Reply #28 on: July 31, 2025, 06:49:49 am »
Ciao Wardy
I've that schematic in my archive since a lot of time, It was part of a DIY amp relized on the East Europe, but I've Lost the link to the web page
Unfortunately the author of the Audiovalvole project deleted his e-mail contact and for those that want to try to ask something he say to try to theyr's Facebook page, but I've no Facebook registration (and don't want to have one)
Re: Bass PreAmp
« Reply #29 on: September 18, 2025, 06:30:21 am »
So, this is what I'm building for a friend with left over project parts and very limited $$ to work with.  He already has the D.I. box for a bass guitar.
My main concern is the plate voltage on the 6SL7 plates.  I'd like something like 160v-200v on the plates.
I can't remember if I've ever built a B+ rail with nodes A and B not connected to anything?  Also there are no power tubes or other preamp tubes to draw down the voltage.  I acknowledge that at some level this may not be the most efficient way to get the voltages to the 6SL7  ............  but it's sorta what I currently have to work with.
I obviously will need to experiment with the B+ rail dropping resistors.  I'd like node C around 300-310v or less.
Any glaring obvious concern about using this approach?  Any concerns about the B+ dropping resistors overheating?  Is this a reasonable approach to experiment with?
« Last Edit: September 18, 2025, 06:32:51 am by tubenit »
Online Wardy
Re: Bass PreAmp
« Reply #30 on: September 18, 2025, 07:25:35 am »
Hi Tubenit,
I'm not sure of the answer to your question, but I'm building a bass preamp to. Mine will also have a vari-mu compressor and a variable HPF. I've gone a different route re power supply, using as DC - DC booster with an external 12v DC wall wart supply. I've used it successfully in a simpler build before and it works well and is quiet. Also very economic in both size and cost, details attached. I also take the heater circuit at 12v direct DC to the tubes. So pre booster it heats then post it provides the plate voltage.
https://www.ebay.co.uk/itm/186640876985?_skw=dc+dc+High+Voltage+Boost+Module&itmmeta=01K5EC92VVXNY97XZ88FWG586F&hash=item2b74a9c5b9:g:~bcAAOSwGadkJARr&itmprp=enc%3AAQAKAAABAFkggFvd1GGDu0w3yXCmi1dkSk1oEcZyHqMGbxswm%2Fc%2BQj%2BW9AdAEROs4kIJ%2BzxL9MzEMI1Sw0wsJtBzAjMRBnK0IP4SYX7D7V%2FAGeWUR09h8aK%2FqctaiwZkyS0PxF3r5e3vP8Upqbh%2BI471jLT%2FBJn%2FrNUEiE4BufFrmTgv5w5HunRWXtx3dyAqtfHPXNzVO8SAtox1yRWa5AISBQXMRePVoTCLqf8TAZCd5SvQO8Ikei2rpwA177u3vg0U%2BIA5HFrxvuQcRQT540IdrtXIkHhl1hm2iknb8CJXXNnUe2u9NHPObBNCk28ByKFueaMvKVnx6jjcigpZrKdu4yR4gy8%3D%7Ctkp%3ABFBMxq6kzKtm
best
Steve
« Last Edit: September 18, 2025, 07:30:20 am by Wardy »
Re: Bass PreAmp
« Reply #31 on: September 18, 2025, 10:53:16 am »
I was aiming for 300 - 310v on node C on the B+rail.
Using 8.2k & 22k got me 307v.
Anyone see anything problematic using this approach where node A and node B are not connected to anything?
Offline passaloutre
Re: Bass PreAmp
« Reply #32 on: September 18, 2025, 01:25:53 pm »
I don't see a problem. The filters are sequential and cumulative, so it should be nice and steady at node C. Obviously your C+ voltage would be lower if you had plates and screens pulling from A and B, but that doesn't mean you *have to* use A and B.
Note: I've always been curious about using something like this where I just need to power a tube or two: https://www.amazon.com/dp/B0D9VCYBLB/
They seem to be aimed at the Nixie tube crowd, so maybe they'd be too noisy for audio applications.
« Last Edit: September 18, 2025, 01:32:35 pm by passaloutre »
Re: Bass PreAmp
« Reply #33 on: September 18, 2025, 03:00:58 pm »
Thanks for the reply!  That device does look like a very interesting approach. Appreciate your sharing it.
Re: Bass PreAmp
« Reply #34 on: September 24, 2025, 12:33:41 pm »
Absolutely dead quiet at idle!  Voltages are what I was aiming for. Sounds good to my ears with guitar ........... will let the bass guy give a final verdict. Loosely modeled after an Ampeg B-15.  It will run into a D.I. then P.A. system.
The wood cab is mostly 101 yr old yellow pine from a hosiery mill in North Carolina where my church is located.  Trim is analine dyed slightly figured cherry. Front panel is some scrap maple I had around.  Half blind dovetails were used.
Made from lotsa left over parts and as inexpensively as I could.
The interior looks different now with a 12A_7 instead of an 6SL7 which was waaayyy too noisy for me. Incredibly quiet now. And I ran the heater wires differently.  The schematic updates the plate and cathode values.
With respect, Jeff
Re: Bass PreAmp
« Reply #35 on: September 24, 2025, 12:35:14 pm »
SCH files
