September 08, 2026, 04:41:37 pm
Hoffman Amps Forum image Author Topic: Rebuilding Fender Deluxe Reverb Reissue  (Read 5640 times)
Offline jaster55
« on: July 29, 2025, 03:06:23 pm »
I want remove the PC boards from my 65 deluxe reverb reissue, and install Eyelet boards and small parts from Hoffman...
Can I use existing transformers for this project.
Thanks in advance
Offline stratomaster
  • Don't guess, measure.
Re: Rebuilding Fender Deluxe Reverb Reissue
« Reply #1 on: July 29, 2025, 03:23:36 pm »
Yes. Duplicate the dual stage filtering on the bias supply shown in the reissue schematic, though.
Online glass54
« Reply #2 on: July 30, 2025, 05:34:19 am »
Hi Jaster
Ive done a few of these. The Fender DRRI makes a FANTASTIC donor amp. Proved to be very stable rebuilds.As requested by my friends, I've kept the Transformers, Tubes+Sockets and heater wiring, Speaker and reverb tank. Double check all the tubes sockets as I have found "dags" of solder which flowed touching chassis and poor joints in heater wiring. REMOVE C31/R65 and fit s/c! Very unreliable PS section. Fit 47u 600V or 500V F&T Electro, you won't be sorry. Check C33 and C34, be vigilant and replace if req, esp C33.
Good luck and keep us posted
Regards
Mirek
"To measure is to know"
Offline jaster55
« Reply #3 on: July 31, 2025, 09:22:59 pm »
Thank-you so much... This a big help... Very Encouraging
I'll probably have more questions once I get started
« Reply #4 on: August 01, 2025, 06:23:20 am »
If you're planning on using full size 3/8" shaft potentiometers all the holes on the faceplate and chassis behind it will have to be enlarged (drilled out). I just left the faceplate on while doing it.
Offline jaster55
« Reply #5 on: August 01, 2025, 07:42:54 pm »
Thanks... I always use CTS pots
