September 08, 2026, 04:41:33 pm
Hoffman Amps Forum image Author Topic: "bleeder" resistor from primary fuse  (Read 3165 times)
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« on: July 31, 2025, 01:39:56 pm »
I'm working on a Cordovox conversion. https://stillampd.com/cordovox
The original schematic does not show it, but the original as built design had a 100k resistor from fuse to ground. Had a 2-prong AC cable.
Gemini says this could be a "bleeder" to ground or for static discharge. Is this right? How would it work?
I've never seen this. As I move to a three prong power cable do I still keep this resistor?
Pic shows the 3 prong upgrade with 100k off fuse.
Re: "bleeder" resistor from primary fuse
« Reply #1 on: July 31, 2025, 03:21:36 pm »
Not needed.
