September 08, 2026, 04:42:17 pm
Hoffman Amps Forum image Author Topic: Did I ruin my resevoir e-cap?  (Read 4115 times)
Offline pullshocks
« on: August 05, 2025, 05:28:35 pm »
Dagnabit, I applied AC for a few minutes before noticing I had the resevoir cap wired backwards.  Any chance it will still work if I rewire it correctly?
Thanks in advance.
Re: Did I ruin my resevoir e-cap?
« Reply #1 on: August 05, 2025, 05:33:01 pm »
 :laugh:
if the guts ain't all over or there was no swelling or "warmth", maybe, but it's definitely time to order a few spares
« Reply #2 on: August 06, 2025, 05:09:49 am »
A second or 2 maybe survivable, but a few minutes? It'll be wrecked.
« Reply #3 on: August 06, 2025, 01:23:07 pm »
If it was a simple power supply circuit with a single cap from ground to B+, yes it likely damaged.
If the circuit called for 2x stacked caps at the reservoir position, and the cap closest to the B+ was positive/forward polarity to B+ but you put the cap closest to ground with positive polarity to ground, you’ll have made one joined up bipolar cap, which will be fine, but unusual...
« Last Edit: August 07, 2025, 09:21:08 pm by tubeswell »
Offline pullshocks
« Reply #4 on: August 06, 2025, 03:02:36 pm »
I'm updating the complete schematic but here is the power supply
I tried rewiring the cap, didn't like the B+ readings I got. So I replaced the cap.  Even with the 2nd cap, something is not right, low B+....
ARRRGH, as I type this I just realized the amp is still plugged into the light bulb limiter,   :laugh:
Anyway, I think the first cap survived the insult, but I'm not going to put it back
Thanks, folks, appreciate everyone jumping in so quickly
Offline pullshocks
« Reply #5 on: August 06, 2025, 04:01:46 pm »
OK, I got the LBL out of the picture and things are working as they should.
Thanks again.
