September 08, 2026, 04:42:56 pm
Hoffman Amps Forum image Author Topic: Cordovox Conversion  (Read 9726 times)
Offline scstill
  • https://stillampd.com
    • Still Amp'd
Cordovox Conversion
« on: August 20, 2025, 11:11:58 am »
I recently bought a Cordovox Amplifier and Tone Generator. I thought this would be a great project for converting to a 212 guitar amp with a 212 extension cabinet. Much of the cabinet mods have been done and now it is time to dive into the circuit design.
Goal to keep as "Vintage Cordovox" as possible converting to a low noise, clean sounding guitar amp. Following the Cordovox design, the guitar amp will be a 7591 push pull with a 12ax7 Cathodyne Phase Inverter and several 12ax7 (or 12au7) preamp stages.
I plan to use this thread to seek expert opinions on the approach and to understand the Cordovox design quirks. I have posted the design history here https://stillampd.com/cordovox
Original Cordovox schematics are in the link
Below is the Cordovox Conversion schematic, with an attempt to keep as much of the Cordovox design as possible, it is modified to meet layout and guitar amp design. There are three separate chassis': Power amp, Control Panel and PreAmp. BTW - there is only one 12ax7 in the preamp (Left side) other socket is empty
Would appreciate any comments on the design which is mostly Orig Cordovox. In particular:
1) Power Supply rectifier and reservoir cap design from Cordovox.
1b) is the voltage handling on the two res caps equal to twice the rating of the individuals
2) All the Cordovox design at the Speaker output. Will be running at 8ohm and 4 ohm with extension
3) Orig Cordovox Super small coupling cap at preamp 2
4) Lack of by pass cap on both preamps
5) Input grid cap on Preamp 1
6) Another conversion added thermistors on the input ac to control surge because the PT in Cordovox was driving 66 tubes that are no longer present https://noisemikers.com/cordovox-accordion-amp-conversion-with-schematics/
« Last Edit: August 20, 2025, 02:55:37 pm by scstill »
Offline Carlsoti
Re: Cordovox Conversion
« Reply #1 on: August 20, 2025, 06:56:27 pm »
Watching, with interest. I've got one that I stalled on, due to not being able to get the rosette-head screws out to swap the baffles and not being able to find my Dremel cut-off wheels at the time.
Offline scstill
    • Still Amp'd
« Reply #2 on: August 20, 2025, 07:24:14 pm »
Don't cut them off.
This worked for me...
To remove the baffles, the rosette screws that hold the black tolex reinforcement cabinet trim need to be loosened and tapped flush with the inner surface, I did not need to remove them. Loosen and remove the rosette nut, If the rosette spins with the nut you will need to hold the rosette with a pliers. I was able to tap the screw with the nut from the inside creating a bit of space to grab the rosette. Careful not to scratch the rosette, but if you do a dab of black paint will help.
I also waxed all the screws and bolts to make them easier for next time.
Offline AlNewman
« Reply #3 on: August 20, 2025, 07:43:11 pm »
I think it's just a voltage doubler circuit, isn't it?
The power supply should be fine with lower rated caps, although nowadays you can find caps that can handle the full voltage.
https://www.electricalvolt.com/voltage-doubler/
Offline scstill
    • Still Amp'd
« Reply #4 on: August 20, 2025, 08:02:25 pm »
Explains why the original Cordovox design used 150uf 250v capacitors
The doubled voltage is ~420vdc, with half across each cap, 250 is adequate for Cordovox design.
I am using 450v caps so plenty of reserve...
Offline Platefire
« Reply #5 on: August 20, 2025, 10:01:43 pm »
On item #4-Lack of by pass caps on pre-amp cathodes. If you got room, you could add a by pass cap switchable with a SPST switch. That way you could return it to stock setup at the flip of a switch
« Last Edit: August 20, 2025, 10:03:47 pm by Platefire »
On the right track now<><
Offline scstill
    • Still Amp'd
« Reply #6 on: August 21, 2025, 09:42:16 am »
not much room in the preamp chassis but I like the idea.
Will build as is and then will figure a plan to fit bypass and a bigger coupler.
I am excited to hear how this as built Cordovox sounds with guitar input.
It will live in my mancave which is 10x10ish, can you image 412 in that space
« Last Edit: August 21, 2025, 09:44:25 am by scstill »
Offline Platefire
« Reply #7 on: August 21, 2025, 06:11:32 pm »
Yelp 4-12's in a 10x10 space---whoa! That's the same size as my Jam Room. I use a SE EL84 amp through a 10" speaker cab with the volume set on about 2. My hearing is really bad! So now I really have to watch the volume level. I play through a clean amp and use pedals to get my dirt. Easier to control the volume that way. So take care of your ears(hearing)---you only get one set:>)
I'll be following this thread with great interest
Offline scstill
    • Still Amp'd
Re: Cordovox Conversion - Grounding
« Reply #8 on: August 23, 2025, 06:15:17 pm »
All Electrolytics replaced and grounding cleaned up so that there are only 3 stars (Cordovox had grounds in several places).
G1 - the Power Supply and Power Amp
G2 - the Preamp, Preamp Power Supply and Control Panel
G3 - the Speaker and OT (only because it is at the other end of the Power Amp Chassis)
These are all labeled with purple tape in the figure.
Questions:
1) should I keep the ground connection between the upper and lower chassis? this is the bare wire connecting pin 8 and pin 3 on the 9pin connector to the left of the AC cable. It essentially connects G1 and G2, which I'm thinking might be a noise source.
2) am I ok keeping G3? or should it be starred into G1?
« Last Edit: August 23, 2025, 11:05:50 pm by scstill »
Offline Platefire
« Reply #9 on: August 26, 2025, 11:20:42 pm »
I've been looking at your power amp chassis and schematic. Usually when I start a new amp from scratch, I have the majority of the amp grounded on single 1/4" Bolt/nut/terminal located in the area of the input jack that provides grounding runs all the way through to the 2nd power node e-cap and the power amp section grounded to a PT lug like this 5E3 variation example 1st Pix below. All the ground wires are green except the heaters are dark green cloth type. With the 5E3's simple  circuit the grounding is pretty easy to see on the Pix which has worked good for me on new builds.
But with this conversion with all the different chassis, the grounding scheme is kind of hard to change with this old style P to P. I converted a General Electric PA20 Hi-Fi amp that was two chassis for pre-amp and power amp connected by an umbilical cord (Like yours) and I just left the grounding scheme as is. It turned out quite enough to keep me happy. The schematic is below. I would recommend trying it as is and see how it goes. If you ran into some humm issues that was obviously grounding, I would then look at rearranging what I could that might help. Best idea I can come up with??
« Last Edit: August 27, 2025, 12:35:08 am by Platefire »
Offline rafe
  • I have tube amps
« Reply #10 on: August 28, 2025, 11:59:37 pm »
I posted about one I purchased a while back and I am glad you posted this ....I found a site where a guy converted one and put up a schematic of what he did.....pretty good info and I saved the schematic ....I've put the project on hold as there are a few in the q ahead of it ....would you like me to post the schematic (Nevermind)
I missed the schematic you posted it looks better than the one I had
« Last Edit: August 29, 2025, 12:18:03 am by rafe »
Rafe
Offline rafe
  • I have tube amps
« Reply #11 on: September 18, 2025, 06:01:54 pm »
Have you made any progress on this project? I am starting to think it might be easier just to get an accordion?????
Rafe
Offline scstill
    • Still Amp'd
« Reply #12 on: September 18, 2025, 06:46:34 pm »
Yes it is almost done.
Here is the link to hum and buzz issue.
     https://el34world.com/Forum/index.php?topic=32980.msg366813#msg366813
And a link to the build progress.
     https://stillampd.com/cordovox-conversion
Was going to put it back together today but am getting some speaker buzz.
With guitar mods it sounds very nice, Thinking I might live with it for a while as Cordovox design.
But as I stated in other thread, I might rebuild the Preamp 1 and 2 to be more guitar like and less mic like
What do you think?
« Reply #13 on: September 18, 2025, 07:56:19 pm »
60/120hz hum at low volume, maybe live with it
lo-vol white noise, scratchy, possibly
Buzz though needs to be tracked down n eliminated.  i can't imagine any guitarist i've done work for calling BUZZ ok for now.
your pre is separate from the pa??  joined by a cord?
If So;
try n mechanically bind the 2 with a metal C-clamp, unplug, turn off, remove ANY RF-source, (digital e-tronics, leds....), that could be leaking in, make sure input jack is "grounded out"  power up, any noteworthy improvement?
Offline Platefire
« Reply #14 on: September 19, 2025, 12:22:53 am »
Don't your amp have a hum balance control in you heater circuit? Have you tried adjusting that?
Offline scstill
    • Still Amp'd
« Reply #15 on: September 19, 2025, 05:21:01 pm »
Sorry the "speaker buzz" I was referring to is likely mechanical occurring on certain played low notes.
Maybe something in the cabinet, we'll see...
I did try the c-clamp idea and there was a slight reduction in the hum.
Not sure if I can practically implement this. Any suggestions?
All three chassis' are grounded to each other through a wire in the umbilical.
This design does not have adjustable filament balance control.
The adjustable resistor in the original Cordovox power amp is in the speaker circuit that prevents unloaded OT without a connected speaker. Not sure I understand why Cordovox needed adjustability in the speaker circuit.
In general, the amp sounds good, But I still think the hum is louder than I would like.
Maybe I need to rebuild preamp 1 and 2 to be more a more familiar guitar circuit.
« Last Edit: September 19, 2025, 05:25:55 pm by scstill »
