September 08, 2026, 04:42:40 pm
Hoffman Amps Forum image Author Topic: 12AZ7 as DC Cathode Follower?  (Read 3673 times)
Offline dwinstonwood
« on: August 26, 2025, 10:06:41 am »
The datasheet for the 12AZ7 states a peak Heater-Cathode voltage of 200; the amplification factor is 60; and max dissipation is 2.5W.
Sort of looks like a good DC Cathode Follower candidate. And they're not pricey. What am I missing/overlooking?
Thanks!
David
Re: 12AZ7 as DC Cathode Follower?
« Reply #1 on: August 26, 2025, 10:45:00 am »
Beware the Heater filament draws 450mA @ 6.3VAC
https://frank.pocnet.net/sheets/127/1/12AZ7.pdf
« Reply #2 on: August 26, 2025, 10:57:55 am »
Thanks tubeswell. OK, as compared to 300mA for 12AX7's. In a pinch I guess you could wire the 12AZ7 12.6V series for 225mA?
« Reply #3 on: August 26, 2025, 11:32:16 am »
If you have a 12.6VAC power supply…
