September 08, 2026, 04:41:16 pm
Hoffman Amps Forum image Author Topic: Cathodyne bias problem  (Read 3887 times)
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« on: August 28, 2025, 03:46:24 pm »
The 12ax7 PI grid is reading 20v while the cathode reads 40v
It seems the grid should be at about 38.5v.
Have replaced the .01 coupling cap and the .00015 cap.
All resistors measure correct value.
Have tried another tube same issue.
Re: Cathodyne bias problem
« Reply #1 on: August 28, 2025, 04:43:31 pm »
The issue is your meter.
Offline scstill
    • Still Amp'd
« Reply #2 on: August 28, 2025, 05:04:06 pm »
yep that stupid "meter"; measures 20v between grid and ground
but after slapping it a few times, it measures -2.5v between grid and cathode
Thank you for pointing me correctly
« Last Edit: August 29, 2025, 02:31:19 pm by scstill »
