September 08, 2026, 07:33:19 pm
Hoffman Amps Forum image Author Topic: Remove vibrato (tremolo) on Normal Channel  (Read 5307 times)
Offline Axtman
« on: September 11, 2025, 11:06:17 am »
I am working on a friend's Fender DRRI with a Hoffman AB763 turret board My friend bought the amp with the board already installed and I am correcting a few wiring mistakes and component values. I was puzzled why the vibrator was on the Normal Channel. I then realized it was wired like a Princeton, and the vibrato varies the bias on the output tubes. My friend only wants vibrato on the Vibrato Channel and not on the Normal Channel.
Does anyone have a wiring diagram for me to remove the vibrator from the bias and add an optoisolator, like a typical Deluxe Reverb? Thanks.
Re: Remove vibrato (tremolo) on Normal Channel
« Reply #1 on: September 11, 2025, 12:26:35 pm »
Use a Deluxe Reverb layout diagram
Offline dogburn
  • Meddling Kid (but older)
« Reply #2 on: September 11, 2025, 10:06:32 pm »
Those are two rather different circuits, so it may not be a simple switch of components. Could you post a photo of the circuit board? You may well find it easier to get a new circuit board to get to the classic AB763 Deluxe Reverb circuit rather than re-wiring what's in there now.
Offline Merlin
« Reply #3 on: September 12, 2025, 04:03:05 am »
How simple do you want this mod to be? This is the simplest arrangement that springs to mind, based on Hoffmans schematic.
Offline Axtman
« Reply #4 on: September 19, 2025, 12:03:10 pm »
Thank you!
