September 08, 2026, 05:38:53 pm
Hoffman Amps Forum image Author Topic: Pro- amp planning  (Read 35147 times)
Offline Mike-p
Re: Pro- amp planning
« Reply #50 on: October 05, 2025, 02:34:37 am »
Thanks, that's good to know, I have a second hand weber neomag, paper cap and cloth surround on the way for this which was a bit of luck!
Offline printer2
« Reply #51 on: October 05, 2025, 08:01:59 pm »
Just doodled some ideas many moons ago, not an exact fit but maybe some ideas would be useful. On the inverters, the 5C5 uses 220k plate resistors in paraphase whereas mine has one pair of 100k's, oops one should be a 82k. I drew it up with a four pole toggle swich changing the inverters and bypassing the gain stage and tone stack of the Bassman. Just utilizing the four pole switch for the inverter the switch can switch between the two as well as having 220k's for the plates (with parallel resistors to drop down to LTP values).
Other than that a cathode bias to grid leak bias on the input.
Offline Mike-p
« Reply #52 on: October 06, 2025, 02:42:42 am »
That is really neat thanks, I'd been persuaded against complicated switching arrangements but that didn't look too complicated...argh!
Offline Mike-p
« Reply #53 on: October 06, 2025, 04:55:57 pm »
Ok, I probably won't implement the PI switch but I'm pursuing it on paper now in order to stretch my brain!
Seems like the variable grid leak /mv would not drop volume to zero as there is always 56k to ground?
The T bolt has the cathodes of the PI tube biased seperately, first 2.2k/33uf, the second 3.9k unbypassed. For the sake of simplicity (ha ha!) should I have them tied together?as in the 5c5 arrangement?
Switching cathode/ fixed bias shouldn't affect things, unless I'm missing something,  your schematic doesn't seem to include power tube bias.
NFB is disconnected when switched to paraphase pi asking with the prescence control. Am I reading this correctly?
Sorry if I'm asking stupid questions or failing to understand simple aspects of the circuits. I really appreciate all the posts on this thread and I feel each time I sit down with my schematic scribblings I have a better understanding of what I'm trying to do.
« Last Edit: October 06, 2025, 04:58:20 pm by Mike-p »
« Reply #54 on: October 06, 2025, 09:08:40 pm »
output tubes are cathode-bias in that schematic. Bias is bias (and cathode bias is a particular method of biasing). If you want fixed bias on the output tubes, then you have to figure out way of dc-isolating the output tube grids from the preceding driving stage(s) without affecting the way the paraphase inverter attenuates the signal going to the second PI stage's grid. So add more parts
Offline Mike-p
« Reply #55 on: October 07, 2025, 03:51:42 am »
Yes sorry you've said this to me previously. The PI switch would work fine in cathode bias? I'm hoping to build the amp simple, add the bells and whistles, play it for a while and work out what I like and then hopefully remove unessassary complications. Accidentally having the paraphase and fixed bias together would not immediately cause bangs and smoke would it?
I can't see any cathode bias resistor and cap on the bassman schematic.
Offline Mike-p
« Reply #56 on: October 08, 2025, 03:22:07 am »
What exactly is the resistor from the second half of the PI grid to ground doing. I see it is increased from 12k stock to 56k on printer2 schematic, can I increase it further? I am trying to see if I can provide the attenuated signal to the second half of the paraphase pi whilst keeping my mv/ grid leak arrangement with safety resistors.
« Reply #57 on: October 08, 2025, 03:32:56 am »
That 12k resistor is the lower leg of a 270k12k voltage divider that attenuates the signal from the plate of the 1st stage of the PI going into the grid of the 2nd stage of the PI.  Google ‘voltage dividers’ to find out more.
This same voltage divider also doubles as a (270k in series with the 12k =) 282k grid leak resistor for the 6L6 being driven by the 1st triode in the PI.
« Last Edit: October 08, 2025, 03:38:47 am by tubeswell »
Offline Mike-p
« Reply #58 on: October 08, 2025, 03:51:28 am »
Ok great thanks, that's exactly what I thought so I'm getting somewhere mentally anyway! I'll redraw that section and post the schematic later thankyou.
« Reply #59 on: October 08, 2025, 04:11:44 am »
The gain structure of the T-bolt PI is all over the place. 1st triode is a fully bypassed gain stage with a 270k plate resistor and a suboptimal impedance bridge with a 282k grid leak for the following 6L6. 2nd triode also has a 270k plate resistor, but has an input signal that’s been knocked down to 4.2% of the output from the 1st stage, and is also a slightly colder-biased - and unbypassed - gain stage (hence making cathode-current-feedback that further reduces its gain), but it has a better impedance bridge going into its 6L6 than the other side does (because of the 470k grid leak resistor).
To further complicate matters, the shared 200R cathode resistor for the 6L6s is unbypassed, which acts to further reduce gain and ‘even out’ any residual imbalances.
All this is aimed at ‘swings and roundabouts’ gain alterations intended to get a ‘balanced’ push pull output stage. Only it isn’t perfectly balanced, and on top of that, the ‘balance’ becomes more imbalanced as the input signal level to the 1st PI triode increases, which is why it sounds so good.
Offline Mike-p
« Reply #60 on: October 08, 2025, 07:07:54 am »
Really appreciate that explanation and I understood most of it I think!
He's my sketch of the PI section with variable grid leak.
« Reply #61 on: October 08, 2025, 09:33:11 am »
Looks like you’re going for 2 different PI circuits off the same dual triode. After staring at it for a while until my eyes went all swirly, I’d say you haven’t got enough switches to completely separate the two circuits. Having noted that, the other things I’d be concerned about with this idea are:
1) the switches are going to introduce the possibility of a bit of unwanted noise due to all the different wire runs needed, which would ruin the final experience and satisfaction rating of the build.
2) you’d need one multi-pole switch with a lot of poles to make so everything switched at once. This will be a headache to implement.
3) if you’re intent on this idea it might be a bit simpler (but not much simpler) to build 2 separate PI circuits using separate dual triodes - to cut down on the number of switch poles you need (but you’d still need at least 6 or so switch poles).
4) there’s a certain type of allure in thinking you can have one amp that does lots of tricks by adding switches for Africa but the degree of complexity needed will almost certainly beget lots of troubleshooting grief which the actual experience of can be worse than you might anticipate. So it may be simpler to give up this idea and just build one of each type of amp that you run from an ABY pedal.
Sorry to pour cold water - I don’t want to hurt any feelings. Just trying to help with my honest ‘horses mouth’ suggestions.
YMMV.
« Last Edit: October 08, 2025, 09:37:40 am by tubeswell »
Offline Mike-p
« Reply #62 on: October 08, 2025, 10:44:34 am »
Thanks, I need cold water in regular doses, I learnt stuff from drawing it out but I think you're right that I'm asking for trouble and misery trying to incorporate it.
« Reply #63 on: October 08, 2025, 01:38:52 pm »
For your next schematic, may I suggest this straightforward freeware that works on most platforms. Very easy to learn to use and you can build circuits quickly and group components and save these to a folder in the program etc.
http://jschem.bplaced.net/
Offline 8wattjack
« Reply #64 on: October 08, 2025, 09:43:05 pm »
The Pro is one of my all time favorites! In the tweed and black and silver panels. I never had the chance to play a brownie like in Johans video, but imagine it would be similar to my vibroverb or concert. I think you will be really happy with your choice. I just finished a resto on a 65 Pro Reverb and it has the perfect headroom/breakup for moderate volumes on stage. Set it to 10 and use the guitars volume! Love love love these amps!
Offline Mike-p
« Reply #65 on: September 05, 2026, 02:26:36 pm »
Well since my last post I've done nothing except work for very little pay and parenting for even less... More importantly I've got really into Marc Ribot and thereby completely changed my opinion on tremolo...My latest plan is to build the 6g5 but save a preamp tube by making it a single channel as the preamp and tone stack are the same on both channels and simply switch to route the signal through the tremolo circuit or direct to the PI. Any obvious problems?
I've also started looking at the Laney chassis wondering what to keep like the mini PCB for the output jacks and switch? Keep the rivetted in tube sockets or drill them out? If I keep the sockets should I keep any of the wiring? Heater wiring? It's all pretty nice and neat or should a start fresh as it'll be a nightmare if I'm chasing problems with recycled parts?
« Reply #66 on: September 05, 2026, 03:00:37 pm »
It's doable. Use a DPDT switch. You'll need to switch the output of V2 in order to match the dry signal level to the wet signal level and also switch the PI input. It would be so much simpler to just build it like the original, ie, let the guitar signal always go through V4 modulator and use the footswitch to engage the tremolo.
Offline Mike-p
« Reply #67 on: September 05, 2026, 05:11:26 pm »
I'm sorry I'm really trying hard to understand your reply. I asked AI in case I was being stupid but no help.
 The normal channel simply goes triode-tone stack and volume- triode - .05 cap- 1m resistor- coupling cap-PI
Can I not switch the signal before the 1m resistor to EITHER feed v4 phase splitter OR 1M -PI cap.
The 1M resistor is doing what exactly? Correcting impedance between channels? Like a mixing resistor?
If I'm being too stupid for an answer please send me in the direction to improve my understanding. I have the new merlin book and the entirely of the internet to consult.
Thankyou.
« Reply #68 on: September 05, 2026, 05:16:47 pm »
You said you only wanted one channel, or so I thought.
Offline Mike-p
« Reply #69 on: September 05, 2026, 05:31:57 pm »
Maybe I used the term incorrectly. I want to use 4 preamp tubes so I thought, v1 and, V2 are doing the same thing, so can I scrap one and switch the output. Is that single input two channel maybe?
« Reply #70 on: September 06, 2026, 09:17:27 am »
... I want to use 4 preamp tubes so I thought, v1 and, V2 are doing the same thing, so can I scrap one and switch the output. ...
If you only want 1 Channel, and Harmonic Trem, why do you need to switch anything?
Fender already had this in what they built:  erase everything of the Normal channel from the Input JAcks up to the 0.05µF and 1MΩ resistor that feed the Phase Inverter Input Cap.
  - Signal "goes through" tubes used to mix the Dry & Trem signals, but...
  - No trem is added unless the Footswitch allows the oscillator to run:  No oscillator, no-trem
You don't need to "mix" or "switch" anything (except in a manner to enable/disable the oscillator).
Offline acheld
« Reply #71 on: September 06, 2026, 09:36:09 am »
OK, I'm confused.
Could you sketch a block diagram of what you want to do?   No schematic, just blocks with intended function.
Offline Mike-p
« Reply #72 on: September 06, 2026, 11:59:08 am »
Ok thanks sorry I will. So will playing through the trem channel without the trem engaged sound exactly like the normal channel?
Offline printer2
« Reply #73 on: September 06, 2026, 05:15:42 pm »
Darn it, I really should look at the date, was going to reply to the original post and drew up a schematic. Kind of embarrassing as I replied a year ago with one. Oh well, take what you want from it. The third triode which combines the channels with the tremolo is an interesting thing to boil down to something simpler, as said, may need some tweaking. Otherwise the switching from LTP to Paraphase uses a four pole toggle switch to get the plate load resistors right. The wiring would not be too bad if you keep the lines short. Didn't take into account the further discussions, drew it up on a different computer that is not connected to the world. Rather than switching the parts in the PI, switching between two PI's can be done easy enough if you have the tubes to work with. In that case a four pole switch can be used, one for the input to the two PI's, two on the output, would be best to short out the input of the unused PI in case it oscillates or picks up stay noise and amplifies it and radiates it around.
