September 08, 2026, 04:42:13 pm
Hoffman Amps Forum image Author Topic: Hot Rod Deluxe strange issue  (Read 6061 times)
Offline hylaphone
« on: October 13, 2025, 01:07:30 pm »
Hi folks, I have a HRD here with ongoing static noise issues. I've isolated it to V2, seeing between 1 and 2VDC on both grids of the tube. There is also <1VDC on the TMB pots. Leaky tonestack cap would explain DC readings on pin 2 but I'm having a hard time visualizing what would cause the same on pin 7 as it's not present at the C2/R18 juncture.Trying to wrap my head around this before pulling the PCBThank you!https://el34world.com/charts/Schematics/files/Fender/Fender_hotrod_deluxe.pdf
Offline DeepBias
  • Tubes turn music into emotion
Re: Hot Rod Deluxe strange issue
« Reply #1 on: October 13, 2025, 06:50:14 pm »
Before pulling the PCB have you tried with another 12AX7.
The older I get, the more I just like plugging directly into my amp
Offline hylaphone
« Reply #2 on: October 14, 2025, 05:05:21 am »
Yes, no change
Offline stratomaster
  • Don't guess, measure.
« Reply #3 on: October 14, 2025, 11:58:45 am »
Do you get grid DC with no tube present?
How about if you remove power to the relays?
The way I see it is you either have a leaky tube, leaky relay, or conductive board.
Offline hylaphone
« Reply #4 on: October 15, 2025, 08:54:26 am »
Good call, I pulled the connectors from the bias and +/-16V supply, and the DC was still there.Removed the ribbon cable at that tube and found several hundred Kohms continuity between plate and grid pins - BINGOTook a few tries to clean and resolder that cable but it did the trick.Thank you for the help!
