September 08, 2026, 04:41:41 pm
Hoffman Amps Forum image Author Topic: 5F1 built from scratch sound splurry when saturated  (Read 4165 times)
Offline FREYES_7
« on: October 20, 2025, 10:30:16 am »
Hello all
Built another 5F1 from scratch, sounds splurry when saturated,
For my first 5F1 I got this issue, but splurrier, solved it by tiding cables from preamp and OT
Even though my soldering is very lacking, I think the preamp socket cables are tidy, I did a thing with the OT and output jacks tho, which I suspect must be the issue.
Added 470ohm @1W screen resistors and 1.5k grid stopper to power tube 6V6, just in case,
Haven't tested again because I noticed the normal jack input was shorted and have to get a replacement, tempted to get rid of normal input,
Any insight will be appreciated
https://imgur.com/gallery/jxQl4vL
Offline dogburn
  • Meddling Kid (but older)
Re: 5F1 built from scratch sound splurry when saturated
« Reply #1 on: October 20, 2025, 02:10:47 pm »
Sounds like the speaker is buzzy. Have you tested another speaker with it?
Offline FREYES_7
« Reply #2 on: October 20, 2025, 06:36:00 pm »
Thanks, will check!
Offline FREYES_7
« Reply #3 on: November 08, 2025, 05:23:13 pm »
Tested speakers and they are fine, looks like it's the amp
« Reply #4 on: November 08, 2025, 06:07:45 pm »
did you test the amp with another speaker, one in a cab so it's solid???
Offline FREYES_7
« Reply #5 on: November 08, 2025, 06:17:11 pm »
it's a 5F1 with 4ohm and 8ohm outputs,
the 4ohm celestion eight15 is brand new, it's not in a cab, but I have another 5F1 that's working fine and the speaker did not falter when connected to it
the 8ohm celestion greenback, was bought used, it's not in a cab, but when connected to a 5E3 DIY kit from mojotone, it works fine,
I think I will route the OT cables in another way, they might be too close to the preamp section
