September 08, 2026, 04:41:16 pm
Hoffman Amps Forum image Author Topic: Sluckey's AB763 Deluxe Lite build issue  (Read 3878 times)
Offline Jazrok
« on: October 30, 2025, 09:20:45 am »
Hi,
I've just finished building Sluckey's AB763 Deluxe Lite using 300-0-300 PT and 40w OT, running 2 x 6L6GC.
Everything seems to be working correctly and the amp sounds good but it's not very loud - about the same volume as a Princeton maybe... I was hoping for Vibrolux territory. Also, when I turn the amp up loud there is a throbbing sound like there's a tremolo on.
Voltages seem about right 407v B+1, 215v on PI plates and 250v on V1 plates (which does seem a bit high).
I've tried disconnecting the NFB in case it was phase cancelling but it made no difference.
Any thoughts?
JM
I've disconnected NFB
Re: Sluckey's AB763 Deluxe Lite build issue
« Reply #1 on: October 30, 2025, 09:28:36 am »
where did the bias voltage land?
how many speakers have you rolled through?
don't have Steve's schematic handy, goes the amp have trem??
Offline Jazrok
« Reply #2 on: October 30, 2025, 09:42:47 am »
I biased it @ 40mv per tube. Playing through a eminence EM12 which is a very efficient speaker.
Offline stratomaster
  • Don't guess, measure.
« Reply #3 on: October 30, 2025, 10:41:47 am »
Can you measure output power into a dummy load? That's the definitive test for determining if it's outputting as intended.
« Reply #4 on: October 30, 2025, 10:55:16 am »
no trem  https://sluckeyamps.com/misc/AB763_Deluxe_Lite.pdf
Offline Jazrok
« Reply #5 on: October 30, 2025, 07:00:20 pm »
can anyone verify what voltages I should be seeing on pin 2/7 of the PI? I have 57v.
Also,
Pin 3/8 = 90v
Pin 1/6 = 215v
Do these sound right?
Offline SEL49
« Reply #6 on: October 30, 2025, 08:09:28 pm »
Sounds OK.
Offline Jazrok
« Reply #7 on: October 30, 2025, 08:47:07 pm »
I don't have that equipment, unfortunately
