September 08, 2026, 01:11:20 pm
Hoffman Amps Forum image Author Topic: Platefire Update  (Read 11364 times)
Offline Platefire
Platefire Update
« on: October 31, 2025, 12:34:11 pm »
I am now the proud new owner of a Pacemaker. I have been avoiding working on tube amps ever since I found out I had A-fib and a slowed heart rate. I have a bad past record of being bit by DCV in mypast amp projects. So I'm now going to revert to just playing over them. I have a good amp tech friend about 30 miles away i can get to do any repairs I need. I'm still following the forum and have to throw my 2 cents in every now and then. Just thought I would let ya'll know :icon_biggrin:
On the right track now<><
Offline scstill
  • https://stillampd.com
    • Still Amp'd
Re: Platefire Update
« Reply #1 on: October 31, 2025, 01:50:07 pm »
A few years ago my doc recommended a pacemaker with a defibrillator, Haha my insurance wouldn't cover the defib. Since I was close to retirement they suggested waiting for Medicare. Good thing I did 'cause now I don't need it.  Hope your life is better now....
The other day I got my first bite of DCV. Seemed to go thru chest and gave me some mild angina for a day or so. Need to be careful with that stuff.
I'm happy that you will continue to provide your tech wisdom here
and please continue to post your sound bites too....
Offline Platefire
« Reply #2 on: October 31, 2025, 04:47:47 pm »
They told me not to lift over 5 pounds for a month or lift my hand above my shoulders on my left arm. This is to be sure you don't pull the two leads out that are attached to my heart. That is hard to do! You just unconsciously use your arm without thinking. So I picked up a arm sling to restrain my arm so I hopefully won't do myself any damage. No guitar for now but I've been  jamming on my harp one handed:>)
I've looked at your Cordovox build a couple of times lately trying to think of a solution, but everything I can think of has already been tried. There is got to be a solution if you can just fine it.
« Last Edit: October 31, 2025, 04:55:52 pm by Platefire »
Offline bmccowan
  • Better builder than player
« Reply #3 on: October 31, 2025, 06:33:55 pm »
Hey Plate, I hope the pacemaker works out great. I know some folks who have had them for years without problems - except the batteries wearing down. I too have Afib and have had two Electric Cardioversions. i still work on amps but am extremely careful. I try to figure out everything with either no power to the amp, or very low power through a variac. But I just kept myself from buying another project amp (this was a bit of a milestone) :icon_biggrin: and I'm going to start thinning out the completed projects (60 or so.)
Best wishes
Mac
John Prine
Offline Platefire
« Reply #4 on: October 31, 2025, 10:18:10 pm »
I reckon they got my Afib under control with a combination of Eliquis, Propafanone(meds), using a CPAP and a lot of Prayer. The pacemaker is set a 60 BPM where pre-pacemaker it got down in the 30's a couple of times while I was on a heart monitor while sleeping. I feel better and stronger now with the pacemaker. When I'm feeling good, it makes me want to pick up a guitar. So laying off for a month isn't easy!
I have considered being extremely careful working on a non-powered up amp the caps drained down. Trouble is, I thought I was being extremely careful the times I got bit:>) For some reason I get kind of hyped up and nervous when I work on a amp circuit. That may be the reason for my bad record of getting bit. Also in my early amping days, there were sometimes when I was finishing up a build, I would do an all niter to get r dun. That's not wise because mistakes happen when your really tired. But as you alluded to, amping is hard to give up, once you got it in you blood!
« Last Edit: October 31, 2025, 10:25:22 pm by Platefire »
Offline bmccowan
« Reply #5 on: November 04, 2025, 01:25:11 pm »
It sounds like you are making smart decisions. I would not encourage you to do otherwise. These thoughts are just general safety ideas that bounce around in my head.
I plug into a GFCI circuit, but I think that does little or nothing on the DC side.
I always keep one hand in my pocket if working on a live circuit.
I try to be patient and use meter clip leads which I attach with the power off and turn the power on to get a reading - this is slow, but keeps fingers out of a live chassis.
I add filter draining resistors as needed.
Other thoughts:
I used to be a pilot. Pilots use checklists. A checklist could serve as a reminder and boost awareness before going in.
I have thought about putting the project amp on its own switched outlet. A large pilot light mounted in front of you could let you know when power is going to the amp.
Mac
John Prine
Offline rake
« Reply #6 on: November 05, 2025, 09:55:34 am »
Pacemaker?
Is that an EV or a gas engine???  :icon_biggrin:
May you now outlive at least three set of batteries!  :worthy1: :worthy1: :worthy1:
Take care of yourself!
Solid state has no soul........
Offline Platefire
« Reply #7 on: November 05, 2025, 12:50:35 pm »
Well it seems to be the trend going EV so..............except getting a recharge is a little more involved for a PM. BTW they did a device check the other day and it showed I have 7 years charge remaining
That is some very good points on ways to safely work on a tube amp. I'm very familiar with using a list for plotting a plan of what I want to do before going into a amp along with safety steps along the way. I'd say the two most important steps is avoid working on a live amp and even a power down amp you would need to find the safest way to bleed caps that you wouldn't get bit that way. I do have a bleeder jumper cable with insulated alligator clips on each end, insulated hook up wire and a in line 10K/2W resistor that's covered with shrink wrap.
So the challenge will be when one of my favorite amps develops a problem! I know in my rural area, very few people know how to work on tube amps. I know 2 in about a 50 mile radius. May be more but I'm not aware of them. I guess I'll cross that bridge when I
get there:>)
« Last Edit: November 05, 2025, 01:07:00 pm by Platefire »
Offline bmccowan
« Reply #8 on: November 06, 2025, 01:50:47 pm »
I hear you - not many techs in my area either. It's hard to charge enough to make it worthwhile.
BTW - +1 on the bleeder tool, but I was actually referring to permanently installing one or more. I usually use a 220K 2w resistor from the positive side of the first filter cap to ground. It bleeds the voltage pretty fast when the power is switched off.
Mac
John Prine
Offline Platefire
« Reply #9 on: November 08, 2025, 01:14:37 pm »
I was in the Amp repair for about 7 years after I retired. I had the same problem finding it hard to charge enough to make it worth my while. If I charged a reasonable Hourly rate for the research, trouble shooting, finding/ordering parts, actual labor time on repairs and testing, tweaking final results----I couldn't really charge what I felt I had into it. Truthfully I continued it as long as I did, because I enjoyed it. I finally got to where I just couldn't justify it anymore.
You know it's strange, but I don't remember hearing about the permanent bleeder tool before?? First thing I thought of was WOW! seems like that would be dangerous having the main power rail going through a 220K R to chassis! Almost like a direct short. So I guess the current will flow in the direction of least resistance to the rest of the amp until the power is turned of, then It will find the path of the bleeder circuit??? Is that how it works?
« Last Edit: November 08, 2025, 01:18:06 pm by Platefire »
Offline SEL49
« Reply #10 on: November 08, 2025, 01:26:55 pm »
Lot's of people do this. 220K is not a direct short! Far from it. Say your B+ is 440V. Putting a 220K resistor across 440V will draw 2mA. That's a whopping .88 watts.   :icon_biggrin:
Offline Platefire
« Reply #11 on: November 08, 2025, 07:42:16 pm »
Well thanks! I've done a very good job of overlooking that up to now :think1:
Offline rafe
  • I have tube amps
« Reply #12 on: November 13, 2025, 06:13:49 pm »
Pacemaker?
It's the Epiphone version of the Gibson GA5T 1961 Epiphone Pacemaker Grey
Rafe
Offline Platefire
« Reply #13 on: November 14, 2025, 01:03:49 pm »
It's really hard to just quit using your left arm for 6 weeks or not lift anything over 5 pounds. Of course your not so restricted with your right hand, still awkward!I wore a sling on my left arm up until yesterday marking it a month since. Played guitar yesterday. The Dr. kind of leaves it open ended one month or 6 weeks to restrict yourself. I sure don't wand to damage the healing incision or pull the leads lose from over exertion. So I'm may hold myself back a little longer
BTW--That's a cool looking Epi Amp! Don't remember seeing that one before. If I had to guess, I would say that is a Champ like circuit with a tremolo?
« Last Edit: November 14, 2025, 02:39:12 pm by Platefire »
Offline bmccowan
« Reply #14 on: November 15, 2025, 08:07:59 am »
After my Cardioversion the instructions were to lift no more than 10lbs for the first week. When I got home, a 40lbs bag of dog food from Chewy was on the door stoop.
Epi amp - that is a cool one. I think that model is 1961 or 62 EA-50T and is likely electrically identical to the most unusual version of the Gibson GA-5T which has a 5Y3, a 12Ax7, and a 6bm8. Half the 6bm8 wiggles the trem. I've wanted to build one for some time now. I populated a board just before medical stuff stalled the project. Gibson apparently did not have much of an imagination regarding the alphabet or numerals as within the GA-5 Skylark EA-50 Pacemaker family there are at least:
6SJ7 > 6V6
12ax7 > 6V6
12ax7 > 6BM8
6eu7 > 2x6AQ5
6eu7 > 2xEL84
12au7 > 2xEL84
Mac
John Prine
Offline Platefire
« Reply #15 on: November 17, 2025, 10:06:00 am »
I just started back driving. Thank the Lord, I had my wife Connie drive for me while I was out of commission:>). Just hauled off a months worth of trash bags that I had only half filled to keep the weight down. Finally working my way back to kind of a new normal
I haven't had much experience with Epi or Gibson amps. I did have a 1960 GA-40 LP amp until my Son adopted it and also a Gibson Atlas Bass amp. On amps I started out as a Fender user and later had several Peaveys and returned back to Fender tubes about the time I got into amp building/mods. Last few years I been a pretty good fan of Epi Guitars. Considering the cost of Gibson Guitars these days, Epiphone carries enough resemblance of quality, appearance, sound and play-ability of the Gibson's to not warrant the difference in price---for my purposes
« Last Edit: November 17, 2025, 10:09:54 am by Platefire »
Offline bmccowan
« Reply #16 on: November 17, 2025, 03:58:16 pm »
Its great to get back to doing for yourself, even if your wife is happy to help. I soon will be driving my wife around for about a month due to some eye work. That'll not be fun: "slow down, slow down, you are scaring the Hell out of me, there are deer and other animals around!"
I've rebuilt many Gibson amps. The good - they have their own interesting voice, and most of them look cool. The bad - some have weird T-filters that tend to muffle the tone (but those are easy to mod/eliminate) - many have crappy quality capacitors - many have crowded rats-nest wiring that makes re-wiring a challenge. Unlike Fender, there is no consistency of layout, some have component boards, some are point-point, some have terminal strips. They stayed cheap when vintage Fender and Marshall values started their rise 20-30 years ago. But now bargains are hard to find.
I'm with you on Epi and also Squire guitars. I do have a couple of vintage Gibson guitars and love them, but I would not pay today's prices as they should be in the hands of better players. I also have a couple of Japanese Fenders that are super nice, but those have now climbed the $ ladder.
Mac
John Prine
Offline Platefire
« Reply #17 on: November 19, 2025, 11:52:37 pm »
On my two Gibson amps, they worked good and I didn't need to do any repairs. I did look at the board and wiring. Like you said, was a rats nest and if I remember correctly seems like the board was populated on both sides?? I decided to leave well enough alone on the electronics and not mess with them. On the GA-40 LP amp I did do some cab work as when I got it, the tolex was stripped down to bare wood and it had no back plate. So I did my first tweed covering job and did build a back plate for it. Installed new oxblood grill cloth
and the Gibson logo was broken and half was missing, so I made another one out of vinyl base material. It still had the original foot switch that was made out of wood.
« Last Edit: November 20, 2025, 11:18:59 am by Platefire »
Offline bmccowan
« Reply #18 on: November 21, 2025, 08:34:29 am »
Nice work. That version of the GA-40 is one of my favorite amps. Not much in the way of clean volume, but the mellow overdrive at low/moderate levels is really nice. The pentode 5879 in V1 is responsible for that I think. I had to replace the filter caps in mine - they were original and cooked. Most of the signal caps were leaking, so I replaced those too. Some earlier all octal versions of that amp had no eyelet board - a complete rats nest. I have one of those too - sounds great but I cannot keep the tremolo working - others here have had that same problem.
Mac
John Prine
Offline Platefire
« Reply #19 on: November 22, 2025, 03:47:54 pm »
Thanks! That real tweed cover job required a lot of study on my part to get the strips to line up properly. Even with all that the glue bled through and left some dark spots.
Speaking of Gibson Amps, reminds me of the 1966 Gibson Lancer barn find that a friend brought to me, wanting me to get it up and running. It was a Lancer GA35RVT. This was a real headache repair that I think I would classify it as the hardest repair/restoration I ever did. There was some parts that needed replacing that I couldn't locate and a Hoffman forum member had the parts I needed and sent them to me and just charged me the cost of shipping--even though I tried to pay him for the parts, he wouldn't accept anything. So thanks again P Batty. The OT and reverb transformer had been chewed up by rats. I would of like to see how Uncle Doug would have handled this one! Anyway if you would like to check out the 2014 thread, here is the link:
https://el34world.com/Forum/index.php?topic=16444.msg161431#msg161431
Offline bmccowan
« Reply #20 on: November 23, 2025, 07:30:57 am »
I looked at that thread. Wow, you had great patience and got some wonderful help from forum members. I have removed those "T filter" networks from a couple mid 60s Epiphone amps - huge difference. I recall viewing that Uncle Doug vid. He's a talented guy.
Mac
John Prine
« Reply #21 on: November 23, 2025, 07:44:31 am »
I liked steal'n interesting circuits, that one looked "interesting", put it in an SE KT-88 build, took the amp to my Son, a week later he calls n said "It's REALLY LOUD, but there's something muddy'n the sound, had my local tech look at it, he was pulling his hair out trying to figure out WTF you did, finally just cut out a circuit n now it sounds great"
to paraphrase from a Book I read; "All things are possible, not all things are beneficial"
 :icon_biggrin:
Offline Platefire
« Reply #22 on: November 23, 2025, 10:26:07 pm »
Yelp! I had a lot of patients but not much knowledge. The forum pitched in and pulled me through on that one plus a lot of my projects over the years also.
I'm really surprised after laying off playing guitar for a month, that a lot of fingering and bends I did previously, I can't pull off successfully! I'm gaining it back day by day, but very slowly. I really didn't expect that :dontknow:
« Last Edit: November 23, 2025, 10:30:05 pm by Platefire »
« Reply #23 on: November 28, 2025, 12:38:35 pm »
That old saying ‘if you don’t use it, make sure to find it again before you lose it’ or something like that.
Glad to hear your ticker is still ticking.
I still remember my first electric shock at 7 years old. Bad Christmas tree lights were calling me. Next thing the world was going black and I had pain in my chest. Hearts never been strong ever since but I’ve made it into my mid 60s touch wood. There’s no telling what’s going to happen, so just do what you enjoy I say. :-)
Offline Platefire
« Reply #24 on: December 01, 2025, 02:06:52 pm »
I really don't know if my getting shocked by amps caused my Afib or just contributed to it. I've had blockage every since 1985 and got two stints in 2006. Got put on a CPAP in 2024 because my cardiologist said that sleep apnea contributes to Afib. As Afib is under control now but I've had dizzy spells from a slowed down heartbeat(Bradycardia). So now I got the pacemaker to keep my heart a 60 BPM. So I feel better and a little stronger now. I'm willing to keep pushing on as long as the Lord wants to keep me here. I believe Jesus can give healing through a Doctors hands or by his Divine touch. Either way will work :icon_biggrin:
« Last Edit: December 01, 2025, 02:10:59 pm by Platefire »
Offline bmccowan
« Reply #25 on: December 01, 2025, 05:55:08 pm »
For what it's worth. My Cardiologist, who I call Cardi D, says that there is a lot of mystery about how electrical signals control the heart. I had Tachycardia for years before developing Afib. He says that the likely cause, or a major contributor, of mine is stubborn Hypertension. Docs struggled for years to find the right combo of meds. I now take a 4 med cocktail (bad word, makes me want a bourbon) and it's still borderline.
Anyway, I also believe in spiritual healing - so keep on keepin' on, friend.
Mac
John Prine
Offline Platefire
« Reply #26 on: December 04, 2025, 10:18:15 pm »
Yelp, will do! Same to you. I got a guitar picking buddy that wrote and recorded a song titled "Keep on Keeping on"---pretty good tune that I listened to several times lately.
Had some good entertainment today. I don't like the feel of my guitar strap on top off my pacemaker on my left shoulder. So I did about an hour of experimenting of trying to invent a strap arrangement on my right shoulder instead of my left. Of course it kept sliding off?!? So I got an old belt that I could run through the strap to hold it in place. I finally found a combination that worked good by placing the belt right above my abdomen through the strap of the front and over it on the back. Yelp it seemed to work, but it looked really strange :l2: as you can imagine.I haven't gave up on the idea, will have to do some more thinking on it :think1:
BTW--I can play sitting down, which I have been doing but---I feel to put my full force into my playing, I need to be standing up
« Last Edit: December 04, 2025, 10:23:28 pm by Platefire »
Offline bmccowan
« Reply #27 on: December 05, 2025, 10:40:32 am »
Albert Collins played with his strap over the right shoulder. Very wide strap.
I play seated and find that offset bodies are more comfortable. But I like teles, so I built an offset with tele bridge and pickups. Was a fun project. But arthritis is making it hard these days. I might need to relive my childhood and go back to air guitar. :icon_biggrin:
Mac
John Prine
Offline Platefire
« Reply #28 on: December 10, 2025, 10:58:44 am »
Yes, I checked Albert C out and yelp---a extra wide strap but in other pixs just a normal width. I tried my widest strap and it would take me a long time to overcome the un-easy feeling of wearing my guitar that way. Like you, I play now sitting down, so it rest on my leg and takes all the pressure off my shoulder. I guess I think that some time in the future I will be in a band again, but that's highly unlikely unless the Lord says so :icon_biggrin:
If you've got a picture of your offset tele, post it, I'd like to see it! Only guitar I ever made was a Flying "V" back in the 70's  that I made from parts of my Grandpa's 60's Japanese hollow body guitar that I inherited but the body completely disintegrated, so I used the parts for the V. It looks like a steam punk nightmare :help:
On my guitar playing, I have a back up plan in my closet. When my fingers won't move anymore, I have a lap steel and will go to a slide. Then if that don't work, then I'll go to air guitar:>)
« Last Edit: December 10, 2025, 11:05:48 am by Platefire »
