September 08, 2026, 04:41:12 pm
Hoffman Amps Forum image Author Topic: Should I paint the Inside AND outside of Cabinet?  (Read 3752 times)
Offline roboDNA
  • I love analog
    • roboDNA
« on: November 10, 2025, 03:50:59 pm »
Hello,
I'm building a 6G15 cabinet and painted the whole thing mat black using premium indoor acrylic water based wall paint.
Is it better to just paint the inside or both the inside and out?  I looks much better fully painted but I'm not sure if the paint affects how well the tolex glue will adhere for the long run.  I read somewhere water based paints such as the one I'm using will not be a problem at all since the tolex glue is also water based.  ( apparently using oil based glue WOULD be a problem )
Re: Should I paint the Inside AND outside of Cabinet?
« Reply #1 on: November 10, 2025, 04:07:54 pm »
I don't se reason to paint the out if you want to use tolex
Offline roboDNA
  • I love analog
    • roboDNA
« Reply #2 on: November 10, 2025, 04:14:36 pm »
True.  I do need to do the inside and doing the outside as well is almost as easy and looks cleaner.  But to your point, my reasoning is if the tolex rips or my corners are not great, black will not show up as much.  I then was going to just paint the finger joints/corners but figured just paint the whole cab.
« Reply #3 on: November 10, 2025, 04:32:12 pm »
You can use paint on scratch if necessary, don't need to paint under the tolex, also consider that paint don't resist much to scratch so if a demage happens easily It will trepass tolex and the under paint
« Last Edit: November 11, 2025, 01:08:06 am by kagliostro »
Offline echuta13
  • Elder God
« Reply #4 on: November 10, 2025, 07:28:50 pm »
I've always used gel super glue on a small tear and black shoe polish (or a Sharpie).  I would probably be concerned about glue adhesion being an issue if there was paint on the cab exterior.  Just my $.02.  Might not be an issue. :dontknow:
"When choosing between two evils I always like to try the one I've never tried before."
« Reply #5 on: November 11, 2025, 01:10:52 am »
I use Contact Glue Bostik 99
Offline Lectroid
« Reply #6 on: November 11, 2025, 04:13:29 pm »
I don't paint wood if I'm going to use contact cement on it.  If you do, let it dry a couple of days to be sure.  I'm also a fan of super glue/marker to fix dings.
Painting as a visual backstop sounded good to me at first, but then I thought that any ding sharp enough to cut through tolex has a decent chance of cutting into the wood as well.  ymmv
Magis bos clocca!
Free Beer Tomorrow!
