September 08, 2026, 04:41:27 pm
Hoffman Amps Forum image Author Topic: DR103 Preamp build  (Read 3307 times)
Offline hiegdk
  • Tube noob
DR103 Preamp build
« on: November 20, 2025, 06:57:48 pm »
I'm considering building a standalone preamp based on the DR103 circuit here: https://hiwatt.org/Schematics/DR_PreLinkedInput_v1.gif
How should the Output 1, Output 2, and OT tap connections be handled? I suppose I should be ommiting V4? If the intent is to simply have an output suitable for running into a power amp what modifications should I be making? Thanks!
Re: DR103 Preamp build
« Reply #1 on: November 20, 2025, 09:53:17 pm »
Yes, for that particular preamp, as a stand alone preamp I agree. Just keep V1, V2 and V3 and leave out the LTP. The CF will be ideal for driving the signal cable to your power amp etc.
Offline hiegdk
  • Tube noob
« Reply #2 on: November 20, 2025, 11:29:43 pm »
Is it possible to retain the Presence control in that case? Would I just source the tap from pin 3 of V3?
« Reply #3 on: November 21, 2025, 02:47:58 pm »
No you can’t retain the presence control from the amp - because it takes its feedback source from the OT secondary, and you would only be building the preamp.
However, if you want an active tone control that functions like a presence control, you could incorporate such a device into the preamp. Google is your friend.
« Last Edit: November 21, 2025, 02:50:29 pm by tubeswell »
Offline hiegdk
  • Tube noob
« Reply #4 on: November 26, 2025, 01:49:10 pm »
Gotcha, thanks!
