July 25, 2026, 06:54:14 pm
Hoffman Amps Forum image Author Topic: 2 questions- Tube values and pot value  (Read 5393 times)
Offline pbman1953
« on: November 26, 2025, 09:54:16 am »
I'm rebuilding another Super Twin into a bass amp.
1-I want to add a bias supply , like I have in the past, before the Output control.  I was told to use a 2.5 pot with a 1.5k resistor. I have the resistor but I see 2k and 3k pots but not many 2.5.  Can I go with the 2 or 3 k? If so do i need to change the resistor value?
2-I have a Sencor TC142 tester. I know it's on the low end but it will at least tell me if a tube is bad. I'm testing the amp's 12AU7 and the reading is questionable. All the other tubes, 12ax7, 12at7 & 6l6's tested fine. From my stash I tried another AU7 and it had the same questionable results. I thought my stash tube was fine. Is the 12au7 different in a way to fool or not read right on a tester?
Offline pbman1953
Re: 2 questions- Tube values and pot value
« Reply #1 on: November 26, 2025, 12:25:43 pm »
Sending the correct Schematic
In the past , my other models had a 820 ohm resistor to ground of V1B's pin 3. This one has a 1.5k. Members, in the past, have suggested to change that part to a 680 ohm.
Should I go with that, or leave it?
« Last Edit: November 27, 2025, 08:39:19 am by pbman1953 »
Offline pbman1953
« Reply #2 on: November 27, 2025, 07:20:32 am »
Anyone?
Offline astronomicum
« Reply #3 on: November 27, 2025, 07:54:32 am »
No. It is always possible that both tubes read low especially if they are both well used. I use a TC142 and find that used 12AU7s typically read a bit lower than used 12AX7s but not questionable (I assume by "questionable" that you mean between 50 and 70%). Testing a new tube might provide some insight. It is also possible that the issue is in your TC142. You may want to service it if you have not already done so.
Offline pbman1953
« Reply #4 on: November 27, 2025, 08:37:41 am »
Yes more like in the 50-70% area. I think the Sencor is ok, all the other tubes test fine, only the 12au7's test weaker
Can you answer the other questions above?
« Reply #5 on: November 27, 2025, 09:17:08 am »
I assume that you want to keep this stage clean since you intend to use it for bass? If I where to be faced with these choices and knowing what "I" wanted the stage to do, I would run load lines on all three and pick the one that is closest to center biased, or change the resistor value to do just that.
I would need a sketch as to what you intend to do in question one (sorry but I don't understand what you are asking) in order to provide comment.
Happy Thanksgiving  :icon_biggrin:
Offline pbman1953
« Reply #6 on: November 27, 2025, 09:35:15 am »
Look at V1B, pin 3. There's a 1.5k resistor to ground. In the generation after this one,  they changed it to a 820 ohm. On my last unit upgrade the forum suggested to use a 680 ohm.
My question is should I leave the 1.5k or install the 680 ohm?
« Reply #7 on: November 27, 2025, 09:55:16 am »
It was this "question 1" I was referring to. This is the one I do not understand.
Offline pbman1953
« Reply #8 on: November 27, 2025, 10:00:07 am »
ok, I've done this in the past but I have a 20k pot so I'd need to know what value resistor to use
« Reply #9 on: November 27, 2025, 10:21:06 am »
You do not need to change the value of the 1K5. The 20K will give you a more negative voltage if you sweep it up to 20K, but at 0(zero)K, it will give you a voltage similar to what the 2K5 pot would give you at 0K.
Offline pbman1953
« Reply #10 on: November 28, 2025, 05:22:31 pm »
Doe this look right?
Offline pbman1953
« Reply #11 on: December 02, 2025, 10:23:52 am »
In the past , my Super Twin models had a 820 ohm resistor to ground of V1B's pin 3. This one has a 1.5k. Members, in the past, have suggested to change that part to a 680 ohm.
Should I leave it or change it?
Offline ac427v
« Reply #12 on: December 05, 2025, 07:48:44 am »
What a beast!!!
You are in a great position to answer the V1b cathode resistor question for yourself because you have experience. What value did you choose the last time you rebuilt a Super Twin? How did that work out?
Or you can run a load line to see what the best theoretical value is. If you do this, make sure to calculate using the funky 47k ohm value for the plate load--not the standard fender 100k ohm.
Or you can try different values by tack soldering in 1500, 820, or 680 resistors and seeing how they sound.
Have at it!
Offline pbman1953
« Reply #13 on: December 05, 2025, 10:32:11 am »
What a beast!!!
Have at it!
The last 2 have the 680 but I didn't experiment. I installed them and ran with it.
Offline pbman1953
« Reply #14 on: December 06, 2025, 08:18:22 am »
I had a chance go back and forth with the 680 & 1500. I left the 680 because compared the 1500 sounded cloudy, where the 680 was crisper.
