September 08, 2026, 04:42:15 pm
Hoffman Amps Forum image Author Topic: Testing an inductor coil  (Read 3316 times)
Offline pbman1953
« on: November 30, 2025, 10:23:11 am »
Is it enough to use a multimeter continuity test to test an inductor?
I have this Fender amp with 6 coils-
#1- no continuity
#2- 130 ohms
#3- 55 ohms
#4-32 ohms,
#5 -16   "
#6- 9     "
I have a feeling #1 is bad
« Last Edit: November 30, 2025, 10:34:20 am by pbman1953 »
Re: Testing an inductor coil
« Reply #1 on: November 30, 2025, 10:47:26 am »
Usually NOT
Obviously if It results open it is a bad thing
You require a specific item
Someting like this
www.ebay.com/itm/176909809975?_skw=esr+meter
Those items measures also impedency
« Last Edit: December 01, 2025, 06:38:44 pm by kagliostro »
Offline pbman1953
« Reply #2 on: November 30, 2025, 10:52:45 am »
Thanks!
 A question on the rebuild.
Should the v1B pin 3 resistor stay as is with the 1.5k or be replaced with a 680 ohm? I think on my last rebuild one of the forum members told me to do that
Thanks!
Offline pbman1953
« Reply #3 on: December 01, 2025, 10:19:58 am »
Any thoughts on my resistor question?
Offline Merlin
« Reply #4 on: December 01, 2025, 11:12:59 am »
I don't see why it should be changed but you could use whatever value sounds good to you.
