September 08, 2026, 04:41:07 pm
Hoffman Amps Forum image Author Topic: I'd love your input on this design idea. Dumb-Lux  (Read 4972 times)
Offline markmalin
  • Malin Sweet Loraine
    • Malin Amplification
« on: December 01, 2025, 11:39:33 am »
Hi, all
I'm trying to lay out a 2 channel amp based on an AB763, but with the following:
- No Vibrato
- 2 channels
- one channel based on a Vibrolux, the other a Dumble #185 (w/out OD)
- both channels will have Reverb
Please have a look at this schematic.  There are some specific things I'm uncertain about:
- placement of the choke
- mixing the 2 channels into the reverb.  Basically I have them both feeding into the gain stage that typically is only used by the Reverb channel on an AB763
- Do I need another section of the filter supply (an E section), or am I OK with just B, C and C?
- Placement of the Master Volume.  The 220k/47k voltage divider in front of the Master is somewhat left over from the original design.  Is this correct?
I really value you'all's expertise and input.  Again, the goal is a 2 channel amp, Dumble (#183 with no OD) in one channel, Vibrolux Normal in the other.  Reverb in both channels, Reverb, PI, power section based on the AB763.
humbly,
Mark
"... there are Flying V's and then there are the ones shaped like peanuts..."  - my son at age 9
Offline SEL49
Re: I'd love your input on this design idea. Dumb-Lux
« Reply #1 on: December 01, 2025, 12:52:46 pm »
Choke is fine.
That's fine. A simpler way is to just connect V1B plate directly to V2B plate, thus eliminating the .05 cap on V1B plate. (See Robinette's drawing)
Fender always used one filter node to supply 6 triodes same as your schematic. Many people, including me, think that's not good enough. I would use a node E to supply V1 and V2, leaving node D to supply only V4.
You don't need the 220K. I suggest using a 100K master volume pot and eliminate the 220K and the 47K.
Offline markmalin
« Reply #2 on: December 01, 2025, 01:27:31 pm »
Thanks for the suggestions.  I've modified my schematic (attached) to include:
- another supply node, E
- removal of post recovery triode 220k/47k divider and 100K master instead of 1M
- changes to the mixing of the channels for reverb.
For the reverb channel mixing I read both of Robenette's mods and he suggested the 220K mixing resistors to keep the channels from interacting with each other and allowing them to be bridged...so it's slightly different from your suggestion.
Offline dogburn
  • Meddling Kid (but older)
« Reply #3 on: December 01, 2025, 04:05:00 pm »
Minor thing on the schematic: you've got a couple of mixed up labels on the tubes - I believe the Reverb Recovery should be labelled V4a and the second PI triode should be V5b rather than V3b.
Offline markmalin
« Reply #4 on: December 01, 2025, 04:11:02 pm »
Thanks!  I'll fix that :)
Mark
Offline acheld
« Reply #5 on: December 01, 2025, 04:11:26 pm »
Complex amp!
There is a 10pF cap coupling your two pre-amp circuits with the output driver.  Most Dumble style circuits I'm aware of will use a 0.005uF cap in that position.    The larger cap will pass more low frequencies, but how much difference in your tone it makes -- I'm not sure.  In my own amps, it sometimes will make a big difference, but not always . . .
Offline markmalin
« Reply #6 on: December 01, 2025, 04:45:18 pm »
Complex amp!
I see the 0.005uf cap at the output of the OD circuit on the Dumble ODS (#185).  But without the OD, there is a 0.05uf cap coupling the plate of V1b (the output of the clean section of the Dumble) to the Master and input to the PI.  I'll have to keep these in mind when I get the amp up and running.  Thanks for the info.
« Reply #7 on: December 02, 2025, 08:18:44 am »
Mark,   I always appreciate your amp building handiwork and that you share it!  Grateful. I find it consistently of interest to me.
I borrowed some from the Dumblish preamp and built that into a cathode biased kinda sorta approach to a DR. There may not be anything useful in this schematic, but I'll share it incase there is to someone else.
I will say, I found a need to adjust (reduce value) some of the coupling caps to get the tone I wanted.  I also found the modification I'm showing on the PAB to be of help to me also tonewise.
I'm getting some of the best clean tones I've ever gotten from any of my builds. Very very happy with it.  The PT is 300-0-300 .............. and I've used 6K6's with a 5Y3GT,  6V6's and 5881's with GZ34.  Since it's cathode biased, I've not need to rebias the tube changes.
I used a Digitech RV-7 and a delay in the psuedo pretend active FX loop.
EDIT/CORRECTION:  The shared bias resistor for the power tubes is 300ohm not 360ohm.  The PT and power rail are on following pages of the SCH schematic along with the relay switching info.
With respect,  Tubenit
« Last Edit: December 02, 2025, 04:27:43 pm by tubenit »
Offline markmalin
« Reply #8 on: December 02, 2025, 04:04:49 pm »
Thanks for the kind words, and for your help and input.  I will take a closer look at your schematic.  I'm intrigued by the idea of changing the coupling caps to change the tone.
I'm curious about the D-style preamp going into alternate power sections.  I tried to do a Dumble preamp into a DR power section, but it just had no life.  Long story short, the chassis was dismantled and I took the parts and made one of my favorite gigging amps so far...but I digress...
That cabinet is beautiful!  I need to learn how to do that - I have this Filmosound I just finished and it's dying for a nice, hardwood head cab.
Mark
Offline acheld
« Reply #9 on: December 03, 2025, 10:07:46 am »
I've built several D-style amps, and have not cracked the code on "knowing" what will work and what won't in the schematic stage of the build.  I've always had to adjust various component values  to make sure there is adequate signal feeding the power amp, but have not seen a pattern of what works other than that.
Been meaning to build a Dumble pre-amp into a 15 watt (or so) power amp . . . not sure when I'll do that, but that should be interesting.
Offline markmalin
« Reply #10 on: January 14, 2026, 06:03:11 pm »
Hey all
I wanted to give an update/followup on the Dumb-Lux idea.  I have it built, up and running, and I am starting to tweak.  I'm attaching the "final" schematic which relates to this build.  As I tweak things this will change, but this is as shown in the picture.  Here are some observations:
  • Overall the idea works and the amp sounds good.  Lots of sustain clean sustain on single notes, though they are a little too compressed for me.  Like not enough punch.  I do like the sustain, though.
  • The Reverb is a bit too lively, which I will address soon
  • The Vibrolux channel is spot on, and the Dumble side is close and sounds pretty descent with the reverb, though maybe driving it a bit too hot.
  • The Dumble side is a lot hotter than the Vibrolux side.  It's a higher gain preamp design, so this is to be expected, but it never occurred to me how this would differ from the Vibrolux preamp.  It's all good, but when you go from one to the other it's noticeable how differently you have to turn the preamp's volume up to get the same level.
  • As I said, the Dumble preamp drives the Fender style reverb a little too hot, so I'll probably add a voltage divider after the tone stack on the Dumble side.
They are two different animals, for sure.  It's interesting to dial the Dumble in as close tone-wise to the Vibrolux side and go back and forth and notice the nuances between the two.  Sorry I don't have any recordings.  I'm not much of a guitar player, and generally play warm, clean jazz tone, so if I record something, that's what it will be.  Not Rock...I just don't know how to do that any longer.  Getting too old!
I welcome your thoughts on the project.  It is far from "done", but at least it's playable.  The "fake" KT-66's sound pretty good, and very much like 6L6's.
Oh!  That reminds me.  I'll list the plate voltages, but in the end I went with a 5Y3 rectifier instead of the GZ34.  This brought down the voltages about 10% across the board and I like the way that sounds better.  To my ears, anyway.
         GZ34.     5Y3
V1a.  241        210
V1b.  242        211
V2a   214        191
V2b   227        199
V3a   446        382
V3b   446        382
V4a   245        209
V4b   246        211
V5a   239        205
V5b   227        196
V6     449        385
V7     449        385   (bias is set to about 70%)
Humbly,
Mark
