September 08, 2026, 04:41:58 pm
Hoffman Amps Forum image Author Topic: I think I had an idea for a "new PPIMV" that represent a Constant Load for PI  (Read 3820 times)
Previously I was thinking to use a pair of SF using two mosfet, one for each brench of the PI but this thing seems to be way simpler
the difficult thing was to find a 4 ganged pot with the correct resistance value, but it is on the market
the idea is an L-PAD/PPIMV
Offline acheld
I like the idea but am skeptical that the pots would be so precise.   But maybe they are.  I guess linear pots would be close enough.
Interesting!  Let us know how that works . . .
For that use the pot must be Linear, not Logaritmic
Not an optional douable choice, the safe 2M2 resistor introduce too much non linearity and alter the load seen by the PI
After investigation NOT a good idea
Offline CascoSieg
  • I love making music - learning about tube amps
Thanks for doing and posting this test! Good info for everyone.
Can you elaborate on why the PI load changed through the rotation? Looks like it should remain constant, yes?
The problem is the 2M2 resistor that is there to maintain a ground reference to G1 if the wiper (those of the pot connected to ground) loss connection
Rotating the shaft the presente of that resistor modify the taper of the pot that don't result linear and didn't maintain a constant load for the PI
